Found a quiet, need help.
Got a sirius for Christmas and mounted it in the center console. Did not like not being able to see the display so I put it up with the suction cup. Took it for a test run and had the tunes up prety loud. My cell phone rang and I turned it down to take the call. After I ended the call I noticed my car was quiet. No rattle in the drivers door, nothing from the *** end, no clunk from the loose top. I hope it was just a smooth spot in the road as I do not think I could get used to a quiet car.
Anyone else have this problem and how did you get your rattles back?
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
i see alot of you guys complaining about how bad these cars rattle,the only time i hear mine rattle is when the top is in.when i get the weather stripping replaced i think that rattle will go away as well.til then i just turn up the tunes
Received 3,043 Likes
St. Jude Donor '05
Strange thing, these cars. The 89 can have some rattles at low speeds, but as it increases (especialy on the freeway no matter how rough) I dont hear any. Could it be due to the wind resistance "pushing" everything into place?
Then the 90 has more miles, but no rattles anywhere under any circumstances.
