4thgen rims on a 86 vette...
Old 10-05-2005, 07:22 PM
FrostyZ28
FrostyZ28's Avatar
Default 4thgen rims on a 86 vette...
Hey guys, figured I'd register and ask a question here.
A guy I work with has an 86 Vette. I'm going to be upgrading my wheels soon and he wants my stock 16'' 5-star rims.
I know the 4thgen fbody rims "fit" but I haven't really seen pics. Will the offset make them look stupid? I don't know much about the C4's.
Thanks guys!
Pics of my rims can be found Here if they're needed.
Old 10-05-2005, 07:24 PM
AZ Z51
AZ Z51's Avatar
St. Jude Donor '05
They fit and look really good,but you'll need to back space them for the offset
Old 10-05-2005, 07:41 PM
FrostyZ28
FrostyZ28's Avatar
So he'll need to run spacers?
Old 10-05-2005, 07:43 PM
kwik_ta
kwik_ta's Avatar
Location: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I used to have a neighbor that put the 5 stars from a TA on his 87 and they fit and looked decent... although it is obvious what kind of car they came from so it wasn't something that I appreciated.
Old 10-05-2005, 07:45 PM
FrostyZ28
FrostyZ28's Avatar
But they weren't sucked into the wheel wells too bad?
I don't care what they look like on the car, it's his car..I just want to know if they look ok fitment wise.
If he has to run some type of spacer I doubt he'll be interested.
Old 10-05-2005, 07:48 PM
AZ Z51
AZ Z51's Avatar
St. Jude Donor '05
YEP
Old 10-05-2005, 07:51 PM
FrostyZ28
FrostyZ28's Avatar
Thanks.
Old 10-05-2005, 07:54 PM
c4cruiser
c4cruiser's Avatar
He'll need adapters "Spacers" are typically a disc of aluminum that slips on the studs between the hub mounting flange and the wheel. Adapters bolt to the studs on the hubs and have a set of studs for attaching the wheel to the adapter.
84-87 C4's require a 38mm offset to make the wheels sit properly in the wheelwell. Offset is the distance between the mounting flange surface of the wheel and the wheel centerline. Late F-body wheels are typically 56mm so a 3/4" spacer will be needed.
Old 10-05-2005, 08:00 PM
FrostyZ28
FrostyZ28's Avatar
Ahhh ok.
How much are these adapaters and are they safe?
Old 10-05-2005, 09:18 PM
c4cruiser
c4cruiser's Avatar
Vette Brakes has them, as does Mid-America and Eckler's; expect to pay a couple hundred or so. You can also find them on eBay. Some race sanctioning bodies will not allow them for competition use.
As far as safety is concerned they should work fine for street use and some "spirited driving", but I would go with a brand new set from a reputable vendor.
Old 10-05-2005, 09:35 PM
FrostyZ28
FrostyZ28's Avatar
Alright, thanks!
He probably won't go for that
To 4thgen rims on a 86 vette...
Quick Reply: 4thgen rims on a 86 vette...
