Has anyone installed these........
Old 05-30-2005, 11:28 AM
92Roadster
92Roadster's Avatar
Default Has anyone installed these........
if so, did you have to modify them to fit??
seems like mine just won't seat without some modifactions.
Old 05-30-2005, 11:58 AM
Stv50
Stv50's Avatar
If those are door seals the holes should line up. I have some clear ones. If I remember right I had one side that did not line up. I just drilled through the hole into the sill. It installed without a problem.
Old 05-30-2005, 01:10 PM
92Roadster
92Roadster's Avatar
Yea, I am having a real problem around the emergency brake lever. Seems like these sill covers are too tall. Looks like I will have to trim some of to get to seat right.
Old 05-30-2005, 01:16 PM
TA
TA's Avatar
Mine didn't quite fit right around the E-brake either, but with a little persuasion the sill piece would slide in between the E-brake trim and the carpet.
Old 05-31-2005, 02:28 AM
REDC4CORVETTE
REDC4CORVETTE's Avatar
Make sure you put the noched one on the drivers side.
Old 05-31-2005, 05:15 AM
Dudule
Dudule's Avatar
I have those installed in my 92 and they fit well, I just had to drill a hole on the outside part so I could screw them...
I have a black interior, it looks great with those
Old 05-31-2005, 07:30 AM
Aquaman92
Aquaman92's Avatar
I have a 92 and to make them fit I cut a little off because of the emergency brake. I used double sided tape to keep them in place works fine.
Old 05-31-2005, 08:02 AM
LT1Vetteguy78
LT1Vetteguy78's Avatar
Have them here too, had to cut them to get around the ebrake..they are kinda cheesey in the aspects of the way the fit.....but they look nice
Old 05-31-2005, 08:20 AM
runner140*
Support Corvetteforum!
runner140*'s Avatar
No mods necessary. If they are the correct size, there is a left sill protector and a right sill protector. Try switching them.
Old 05-31-2005, 02:35 PM
CREWZIN
CREWZIN's Avatar
I put em on my 87 a few years ago. I've scrapped the drivers side so much getting in and out that most of the white letterng is gone. They fit perfect without any problem.
Old 05-31-2005, 05:07 PM
92Roadster
92Roadster's Avatar
Well as my luck would have it, I have to make some modifications. Thanks for the help.
To Has anyone installed these........
Quick Reply: Has anyone installed these........
