Where is the fuel pump relay on an '88?
Could someone point out where the fuel pump relay on an '88 is? Thank you! I'm changing the bose amp relay (loud pop on turning the radio off/on) and want to change the fuel pump relay to. There is sometimes a long crank time for the car to start. I replaced the MAF burn off and power relays (had a code, replaced them and no code) last summer. The relays seem to be getting bad in the whole car. Has anyone cut them apart and cleaned them? They don't cost all that much but I'm curious about cleaning them. If i was to do that, and put back them together with a screw, then the contacts could be cleaned once in awhile. Just an idea.
The FP relay is near the firewall between the power brake booster and distributor. If you're '88 is a 4+3 you'll have 2 relays in the same place. If its an auto there will be only 1.
Thank you! Yes I have an A4.
