c4 twin turbo kits?
Old 08-05-2004, 02:26 PM
  #41
JZ 97 SS 1500
JZ 97 SS 1500's Avatar
Rkreigh, they are still looking. If you want to be the donor car and recieve the donor discount call Dalton up.
Jose
Old 08-07-2004, 07:25 AM
  #42
Rkreigh
Rkreigh's Avatar
maybe if my 93 LPE sells. still holding out for a TT ZR1, that's really what I'm up for!!
Old 08-08-2004, 01:45 AM
  #43
StealDads67
StealDads67's Avatar
How much exactly is dicounted on teh donor car.
I Have a bone stock LT4. Unmolested. But for someone to rip into my car and stat trying to figure stuff out, there better be a BIG discount to make it worth it if you ask me.
but then again a TT LT4 would be nice (Till it blew up))
Old 08-08-2004, 10:28 AM
  #44
Last Ride
Last Ride's Avatar
From my understanding, the labor is essentially free. That means, all you are paying for are the hot parts and the turbos. The problem on these cars is that I think the compression is too high for any real boost. That means a change to lower CR pistons, which can get expensive in a hurry. As I said before, the tune is the most important thing. I would be very apprehensive about driving the car much without a tune.
Bryan
Old 08-08-2004, 03:33 PM
  #45
JagdStealth
JagdStealth's Avatar
Bryan
Low compression / high compression doesn't matter so much. The final compression number is all that is miportant.
Running 8PSI on a 10.5:1 motor will be almost the same as running 13PIS on an 8.5:1 motor. You just have to run lower boost and calculate what the final CR will be.
Of course boost makes more power than compression points and big turbos like these guys want to sell don't perform very well out of their range like that.
Old 08-11-2004, 06:14 PM
  #46
JZ 97 SS 1500
That is correct. With the right tuning you can get away with the added boost. At least for a while...hehe. The LT1 Z28 that runs the PTK system never had a problem with his, and ran for a long while till he decided to go big with 1000+hp 383 and PTE-76GTS.
Jose
Old 08-12-2004, 01:50 PM
  #47
1fastvett
1fastvett's Avatar
hey Bruce how much does a set up like that go for engine and all?
thank for all your help on my slipping belt.
Old 09-03-2004, 10:15 AM
  #48
SonnyinVA
SonnyinVA's Avatar
i sent them a message to see if they'd be interested in my car. i have forged internals but externally the engine is the same as a stock LT4 or LT1. i actually have it apart right now, and could put in some low compression pistons if they want my car. i could make some serious HP with this kit!
see ya,
sonny
Old 09-03-2004, 10:36 AM
  #49
JZ 97 SS 1500
Sonny if you want to be the donor call Dalton at 210-657-2706. He can tell you when you can be scheduled in and what you will have to pay.
Jose
Old 09-03-2004, 10:39 AM
  #50
SonnyinVA
SonnyinVA's Avatar
thanks jose
Old 09-19-2004, 04:07 AM
  #51
ElisTwoCents
ElisTwoCents's Avatar
St. Jude Donor '05-'06,'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
I'll be keepin an eye on this project
Old 09-20-2004, 08:28 PM
  #52
Turbocharged Power
Turbocharged Power's Avatar
These guys also list a turbo kit for the 84-91 as well as the ZR1 in their "Coming Soon" category at the bottom of the page. They are light on details, so it may just be another pipe dream....
It's not a pipe dream; it is definitely coming soon. They already released the twin turbo C5 kit.
Old 09-20-2004, 10:19 PM
  #53
Last Ride
Last Ride's Avatar
Then I guess I can just say that I will believe it when I see it. If they can produce a twin turbo kit for the ZR1 at a price of what they are producing other kits, then they will truly have captured the unicorn. I'm not knocking the complexity of the other projects, but the reality is that there have been many that have tried before!
Bryan
Old 09-24-2004, 06:47 PM
  #54
comp
comp's Avatar
Originally Posted by Hammer
Give me that setup with 550-600 rwhp running like stock, and you can Count Me In!
I wish this would happen.
Jim
no joke it's
Old 10-21-2004, 11:17 PM
  #55
*89x2*
*89x2*'s Avatar
Location: ...tearing up the highways, one state at a time™®©
Received 2,096 Likes on 1,074 Posts
Originally Posted by Rkreigh
...for the price of installation of a TT you can go out and buy a callaway outright, and hop her up a bit.
I may get tired of waiting and just go that route, as for now, the 505 RWHP of the stroker ZR1 has proven sufficient.
Ron, I know of a 1990 zf6 spd / fx3 Callaway Twin Turbo (coupe) w/ the big Wonderbar already done and hoodscoops upgraded for 23k
The guy at this point is GIVING the car away (about 30k mi) - it is red w/ gray leather and about a 3.5 hr drive away from you!!!
The car has the correct Dymags and was recently at Callaway Cars for a "once over"
Interested???
Old 10-22-2004, 11:48 PM
  #56
89b2k
89b2k's Avatar
I know that some Callaway owners might not agree-but a Callaway with the turbos that come on the car can not support more than 550 rwhp. Larger turbos are the only way to make big hp.The turbos on Callaways are rotomaster designs about the size of t3's. On a 350 cu motor the air flow is maxed past 5000 rpm. I'm not trying to start a fight-just giving my experience.
Old 10-23-2004, 09:54 AM
  #57
*89x2*
*89x2*'s Avatar
89b2k, the last Callaway Twin Turbo produced (completed this past Jan. after sitting in a dark corner of the shop for years) makes appx. 525hp & 675 tque using the standard turbos.
Some owners have recently sent their turbos back to Old Lyme for some upgrades to handle more flow and be more consistent in the wastegates -
~More on the last B2K can be seen here: Last_B2K_Article
I would like to hear more about your 1989 Callaway
in the meantime, check out www.callawayownersgroup.com and dropp by the Callaway_Forum - it is specific to Callaway Corvettes and the owners & enthusiasts who are there are a GREAT Bunch
To c4 twin turbo kits?
Old 10-23-2004, 11:23 AM
  #58
89b2k
89b2k's Avatar
89x2, 525 fwhp is alot different than the 550 rwhp I stated.If this is not true, then I would like to see some dyno graphs of more than 550 rwhp. Did'nt want to start a fight, I just wanted people to know.
Old 10-23-2004, 12:12 PM
  #59
*89x2*
*89x2*'s Avatar
89b2k, I was just posting something I thought you might find of interest, not comparing anything at all here...
If I missed something, let me know...
Old 10-23-2004, 12:34 PM
  #60
89b2k
89b2k's Avatar
Yes you did miss something . The guy said he had 505 rwhp already- the Callaway even if modded will not make anymore than that with the stock turbos.
Quick Reply: c4 twin turbo kits?
