I need help with .bin file for my twin turbo LT1 corvette project
Hello
I need help with .bin file for my twin turbo lt1 corvette project. Could any of you provide .bin file for me to see.
It must be for `93 LT1 corvette either for supercharger or turbocharger that will work with 3-bar MAP sensor.
My project is now in stage of mounting T3/T4 turbos, it has already been stroked to 383 ci all forged. I am
programming on C.A.T.S. tuner but i don`t have enough data to make an EPROM I have never made any blown aplications.
Thanks for any help
Best regards
Thanks for any help
Best regards
Re: I need help with .bin file for my twin turbo LT1 corvette project (Grzenio)
The ECM in your car isn't made to work with a 3 bar map. I'm not saying it can't be done, but you would kill the resolution of your maps. An FMU would probably work better in this case, or better yet a F.A.S.T. or DFI management system. There is also a 034 controller that will allow the use of a 3 bar map, but would require the use of "extra" injectors". Good luck with your build up!
Re: I need help with .bin file for my twin turbo LT1 corvette project (ANTI VENOM)
I now DFI management system is better. I can't afford it right now, that thing is too pricey.
I use 50lbs/hr injectors, 3- bar MAP, remap Chip end SMT6 Piggy-Back.
Re: I need help with .bin file for my twin turbo LT1 corvette project (Bruce)
Twin turbo Corvette project under construction.
[Modified by Grzenio, 4:35 PM 5/31/2004]
wow, The turbo mount so high. The stock hood are not going to clear it ? I just curious why are you not running a large single IC rather than two small IC?
Bruce
Bruce
Turbo mount is ok. I have a special hood.
I`m not running a large single IC. Turbo is a low budget project,( I bought my forged Eagle crankshaft forged Ross pistons, Manleyrods and more.... for my savings) and those two small intercoolers I got for free .
[Modified by Grzenio, 5:30 PM 6/1/2004]
If you do switch to a syclone ecm. I have a 50lb injector program with a 3 bar map that you can look at or use.
Re: I need help with .bin file for my twin turbo LT1 corvette project (new'92)
OK,Thanx I can have the ECM from TYPHOON ,but I really have no idea how to do switch it to my car, May you help me ?
Because it will be the first Corvette TT in my country and nobody else can help me....
I will be very grateful for any help !
May email: grzenio@poczta.neostrada.pl
You'll still have to run the stock ecm and split the inputs if you want that digital dash to work. Can be done, but takes up a bit more room.
Make sure you have a good fuel system. You are gonna make some very nice hp.
Bruce
Bruce
I didnt realize the link I was going to post was already posted above, anyways its for a TPI but I think it could work with an LT1 as well.
