Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-21-2004, 09:53 AM   #1
Carl90
CF Senior Member
Default Safest nitros setup
I have seen setups where the plate is behind the throttle body. Seems that the risk of this setup is solenoid failure dumping nitros into your engine while at idle.
I have also seen other systems where the fuel/nitros is injected in front of the throttle body. With this setup, I would expect that the risk is dumping fuel into the intake tract and risking fire.
I was wondering if a safer setup would be to use the plate for fuel only and add nitros ahead of the throttle body. The idea being that fuel leaking into a manifold is not that critical. Nitro leaking into the intake may escape via the air filter.
Carl90 is offline   Reply With Quote
Old 05-21-2004, 04:36 PM   #2
mike 1985
CF Senior Member
mike 1985's Avatar
Default Re: Safest nitros setup (Carl90)
you worry too much.
you can't seperate them. if you have a wet kit, they have to be together to atomize the mixture.
Either way, keep the bottle off and it'll never leak nitrous, and if it's leaking fuel...well you'll know because it'll be spittting out the black smoke.
Buy a new kit from a reptuable manufacturer and you won't have any troubles
mike 1985 is offline   Reply With Quote
Reload this Page Safest nitros setup
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
