Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-19-2004, 12:55 PM   #1
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Default Accel GEN7 DFI systems
Anyone interested in getting a GEN7 DFI system? If so email me off list I maybe able to save you some $$$
tjwong is offline   Reply With Quote
Old 05-19-2004, 11:38 PM   #2
GM_96LT4
CF Senior Member
GM_96LT4's Avatar
Default Re: Accel GEN7 DFI systems (tjwong)
TJ,
Does that include the 454/502 systems as well?
Thanks in advance,
Glenn
GM_96LT4 is offline   Reply With Quote
Old 05-20-2004, 10:50 AM   #3
tjwong
CF Senior Member
tjwong's Avatar
Default Re: Accel GEN7 DFI systems (GM_96LT4)
Yes it does if interested shoot me an email and I will give you the particulars
Old 05-20-2004, 05:06 PM   #4
mn_vette
CF Senior Member
mn_vette's Avatar
Where were you 3 months ago???
mn_vette is offline   Reply With Quote
Old 05-21-2004, 01:00 AM   #5
tjwong
CF Senior Member
tjwong's Avatar
Default Re: Accel GEN7 DFI systems (mn_vette)
Sorry But it wasn't until recently that I got in with Mr. Gasket but if I can help you with anything else feel free to email.
Old 05-21-2004, 01:54 PM   #6
SloRvette
CF Senior Member
Cruise-In VII Veteran
SloRvette's Avatar
Send a message via AIM to SloRvette
Tom, do you know if you can mix ignition pickup signals, ie. can you use a hall effect crank trigger with an inductive pickup cam signal ?
How do you like the wideband option ?
SloRvette is offline   Reply With Quote
Old 05-21-2004, 02:02 PM   #7
tjwong
CF Senior Member
tjwong's Avatar
Default Re: Accel GEN7 DFI systems (SloRvette)
You know thats a very good question. Yes you can do that. In the G7 ECU set up screen you can define the ignition inputs there. I do like the WBO2 system that Accel offers but I think they should drop the price. It does use a NTK sensor that is not unlike the sensor that my Horiba uses. They tell me that its equal to my Horiba sensor, and I can say that its accuracy is on par when I have the systems side by side sampling the same exhaust pipe.
Old 05-21-2004, 02:21 PM   #8
lead foot 85 vet
CF Senior Member
Tom.......Mac at fasttrackperformance told me that the innovate wideband o2 senser would work with the gen 7 and save some bucks over what accel is charging for the o2 option.
lead foot 85 vet is offline   Reply With Quote
Old 05-21-2004, 04:35 PM   #9
mn_vette
CF Senior Member
mn_vette's Avatar
Default Re: Accel GEN7 DFI systems (lead foot 85 vet)
The innovative system will work and the accel system will work, but they will not work TOGTHER. The whole point of having the wideband O2 system integrated into the computer is so that it can adjust fuel on the fly, innovative won't do that, it's only good for the initial tune. I've talked to several people that have had their engines saved because their wideband O2 compensated for a fuel pump going out or an injector not keeping up to speed. And the fact that its just alot nicer to deal with one system.
Oh, and just to let you know, I've tried the Innovative system with my accel. The wideband box was faulty when I got it so I used that as an innitial tuning device. It's hard to do a run and then compare the datalogging from the accel to the datalogging from the innovative system.
Old 05-21-2004, 06:24 PM   #10
lead foot 85 vet
CF Senior Member
I hear you I have both also.............but I talked to him yesterday and he said you could intagrate the innovative system into the gen 7 system with a wire harness and it would work just like the gen 7 WB02....if it soesn't work automaticly with the gen 7 fuel air correction system then there's no point in using it...............just passing information............maybe if your interested......give him a call.......888-640-3278
what was wrong with your innovate wide band? and I hear you on tuning on the fly......I don't have time to look at all the gadges .........at least at WOT
Old 05-29-2004, 04:53 AM   #11
tjwong
CF Senior Member
tjwong's Avatar
The Innovate system will work with the DFI system. The Innovate has 2 programmable analog outputs. All that needs to be done is to calibrate the Innovate system so that it meets the requirements of the DFI system. The DFI system will accept the signal as it doesn't care what the source is and as long as its calibrated to what the DFI needs for a signal it will be just as accurate as the DFI wide band system. The best part is that its more than half the cost of the DFI WBO2 As soon as I get my hands on a DFI system I will try to interface one of my Innovate systems to the DFI ECU.
Old 06-10-2004, 02:28 AM   #12
Repoman
CF Senior Member
Repoman's Avatar
Sent you some mail.
Repoman is offline   Reply With Quote
Old 06-10-2004, 05:36 PM   #13
scorp508
CF Senior Member
scorp508's Avatar
I wish, I'm just poor.
scorp508 is offline   Reply With Quote
Old 06-23-2004, 07:28 PM   #14
John G 92
CF Senior Member
John G 92's Avatar
Can you get a deal on the super ram intake package with the dfi system? if so how much email me at xxxirocz88xxx@aol.com thanks...
John G 92 is offline   Reply With Quote
Old 06-23-2004, 11:44 PM   #15
tjwong
CF Senior Member
tjwong's Avatar
Default Re: Accel GEN7 DFI systems (John G 92)
You got mail. Plus I have a bit of news for all you DFI GEN7 owners that want a WBO2 sytem but can't seem to justify the Accel WBO2 systems healthy price tag. I have sucessfully integrated the Innovate WBO2 system to the GEN7 systems I am finalizing my calibration curve tonight and I will begin sourcing cabling to make the installation a piece of cake. So that means for a bit more than $350 you can have a functional WBO2 integrated into your GEN7 DFI system to be able to tune on the fly and make corrections. Then once tuning is done the sytem can be returned back to a narrow band system.
Old 06-27-2004, 02:59 PM   #16
Brand-X
CF Senior Member
Tom,
I may need to buy a Gen VII+ key, ever since my move to Atlanta, can't seem to find anything. How much are those things going for these days?
Chris
Brand-X is offline   Reply With Quote
Old 06-29-2004, 12:57 PM   #17
tjwong
CF Senior Member
tjwong's Avatar
Default Re: Accel GEN7 DFI systems (Brand-X)
Chris do you need the sportsman or the pro key?
Old 06-29-2004, 07:53 PM   #18
Brand-X
CF Senior Member
It's no longer an issue...Thanks, Chris
[Modified by Brand-X, 5:53 PM 6/29/2004]
Old 06-30-2004, 11:14 PM   #19
'68LT1camaro
Junior Member
Hey TJWONG, I am interested in using an LM-1 with my Gen 7 DFI set up. I talked to MAC yesterday, and he said he makes a harness to connect the LM-1 to the DFI harness. He said he sells the harness with the LM-1 for $350. What did you have to do exactly to get this WBO2 to work with your Gen 7?
Any help would be greatly appreciated!!!
[Modified by '68LT1camaro, 3:15 AM 7/1/2004]
[Modified by '68LT1camaro, 3:17 AM 7/1/2004]
'68LT1camaro is offline   Reply With Quote
Old 07-01-2004, 12:15 AM   #20
tjwong
CF Senior Member
tjwong's Avatar
Default Re: Accel GEN7 DFI systems ('68LT1camaro)
Basically I fed a signal into the GEN 7 system after defining its usage with a linear O2 sensor. I figured out what the curve was that the G7 system was expecting to see from the WBO2 box. I also got the information from Mac as well, and for what he is selling the Innovate for is a good deal. I don't have the harnesses made up yet to make the connections to the G7 system. I am awaiting my connectors. Basically all the harness consists of is the mating connector to the G7 O2 connector, and a analog output cable for the LM1 which is just a 1/8" stereo headphone cable with a phono plug on the end just like what is used on your walkman. I just don't have the O2 sensor connectors at this time.
Mac and I have some disagreement on what values to use in the programming of the LM1. He told me that his engineer figured it out and gives a voltage spread of about 2.30 volts. I simulated a signal to the G7 O2 input with a special instrument calibration simulation tool. I found that the G7 wants to see a input voltage of 1 to 5 volts, which equals to 10.08 to 19.18 AFR. So what Mac has sent me and what I seen in the G7 systems don't match.
The only discrepency is perhaps how they set up the internal programming of the G7 ECU. With my calculations I set it up for a linear type 2 sensor. I had no way of using a live test on an engine to test what I found to compare what is displayed on the LM1 vs the G7 dashboard. But I feel 99.99% sure that what I found will be accurate and will work. I had over 50 datapoints to plot the curve by and it was definitely repeatable as well.
Reload this Page Accel GEN7 DFI systems
Tags
dfi, forums, gen7
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stand-alone selection and the LT1: Your opinionis wanted. HJV11 C4 Forced Induction/Nitrous 22 08-30-2005 10:59 AM
Engine Management Systems??? Brett Richmond C4 Forced Induction/Nitrous 12 12-22-2004 02:00 PM
Accel GEN7 DFI systems tjwong C4 Tech/Performance 10 05-20-2004 12:45 PM
Accel Gen7 Tuning Help mn_vette C4 Scan & Tune 11 04-17-2004 01:12 AM
did anyone use the new F.A.S.T engine mangment red L98 C4 Tech/Performance 20 10-02-2003 11:43 PM
[CALLING MONTY] Standalone Fuel Management mn_vette C4 Forced Induction/Nitrous 17 03-25-2003 10:39 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
