Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-19-2004, 09:14 AM   #1
jerkyboy
CF Senior Member
jerkyboy's Avatar
Default L98 supercharger on ebay. Opinions?
This is a paxton unit. Comes with all parts and install manual. Reserve has been met at $850. I am assuming this is an older unit but what kind of power can it make? Is it a decent system? Thanks
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
jerkyboy is offline   Reply With Quote
Old 05-19-2004, 10:01 AM   #2
SuperL98
CF Senior Member
SuperL98's Avatar
Default Re: L98 supercharger on ebay. Opinions? (jerkyboy)
This is a very old Paxton kit from http://www.carrollsupercharging.com/
The blue sticker means it is the older either an SN92 or 93 unit, yellow sticker would be a later SN2000 model.
I bought one of the first of these kits back in the 1990's and it's a very complete setup with a big instruction manual. Nice kit for the times but not as good as the newer blowers. Put's out about 5 to 6 psi on a stock motor.
Went from a 14.1 (with the stock L98) to about 13.4 (stock engine) in the 1/4.
Problem would be that these head units don't last that long (as little as 10,000 miles sometimes) and it may need a rebuild at about $750 + $100 for a higher output impeller (from paradise wheel in CA).
Will probably be to small for your 383.
Also need the chip that came with it, I have a copy of the original bin file if you do go this way (all it is a an ARAP bin with a modified full throttle mixture table)
I still have most of the kit installed, upgraded to the later SN2000 with a high output impeller. Puts out about 8 to 9 psi on my mostly stock ZZ4 crate engine.
Now I am around 12.6 to 12.8 110-112 mph in the 1/4 (with 2.59 rear axle)
If you need anymore info post it here, and I'll help if I can.
SuperL98 is offline   Reply With Quote
Old 05-19-2004, 10:06 AM   #3
jerkyboy
CF Senior Member
jerkyboy's Avatar
Default Re: L98 supercharger on ebay. Opinions? (SuperL98)
Great info. Thanks alot! I figured it was too good to be true. I have a DFI system so I am not worried about chips. I will keep looking. Thanks again!
Reload this Page L98 supercharger on ebay. Opinions?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
