Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-08-2004, 05:47 PM   #1
Bigvmaxx
CF Senior Member
Bigvmaxx's Avatar
Default A/O ram air install...
OK... I have everything ready to install... ie... color matched air intake looks great...
Is their a cutting template for the hose ?
Is it easier to remove the hood 1st before making the cuts nessasary to route the hose through the air pathway ?
Is their any tips anyone can suggest for doing this modification ?
Thanks...
Ted
91 # 661
Sun City, CA
Bigvmaxx is offline   Reply With Quote
Old 05-08-2004, 06:48 PM   #2
MrCrowley
CF Senior Member
MrCrowley's Avatar
Send a message via AIM to MrCrowley
Default Re: A/O ram air install... (Bigvmaxx)
Are you planning on doing it yourself? If so, and you arent that skilled with tools, well do your cutting with the hood closed. A 6" holes saw with a 12" depth would be helpfull, but in my case I didnt use it. It does come with templates, but I since have thrown mine away.
Doing body work as a trade for several years I just used a air saw, 1 long 3/8 drill bit, a die grinder, and a cut off wheel. I didnt use the templates either, I just went to hacking away. Its really not that hard just start cutting and fitting and you will get it in no time!
Mike
MrCrowley is offline   Reply With Quote
Old 05-08-2004, 07:01 PM   #3
Bigvmaxx
CF Senior Member
Bigvmaxx's Avatar
Default Re: A/O ram air install... (MrCrowley)
Mike
Iam fairly adept with tools... but not as good as my Boeing employee aero space buddy though...
I have a big dremel with the bit that makes cutting sideways an easy thing to do... I just don't like to start cutting before knowing exactly how it should look when its done... Iam sure you know what I mean...
Thanks for the imformation... going through the license plate area sounds a whole lot easier than going through from the engine side...
Old 05-08-2004, 10:21 PM   #4
MrCrowley
CF Senior Member
MrCrowley's Avatar
Start at the license plate area, and cutt the largest portion you can out of it. That will help you with the room you need to cut the rebar. And do remember you will need to cut alittle bit of the xbrace connecting the 2 frame rails.
Mike
Old 05-08-2004, 11:08 PM   #5
chillcat
CF Senior Member
chillcat's Avatar
What I found making the job easier is start drilling holes like they said through the front plate area into the radiator shroud until it looks like a clint eastwood job. Then take a reciprocating saw and go to work just cutting away---basically its pretty simple until its time to run the air duct up the newly formed hole---so make sure you don't leave any rough edges up through the shaft--cause you don't want to tear any holes in the air duct--at least I wouldn't want to....but finally putting the new intake base into position and fitting the hose into it, might take a few minutes to work with---but good luck--I love my finished project--sounds a bit louder outside the car now with that tornado sucking noise....
chillcat is offline   Reply With Quote
Old 05-09-2004, 03:53 AM   #6
Bigvmaxx
CF Senior Member
Bigvmaxx's Avatar
Default Re: A/O ram air install... (chillcat)
Thanks for the imformative replies... it seems this won't be tough at all now... I was dreading a hood removal... they are very heavy and awkward... Iam going to look for some edging material to run around most of the cut out area... that should help protect the hose from developing a hole...
Were going to do the dyno test on May 22nd... the 1st pull without the blower... and the 2nd with the 212 mph leaf blower on... the car runs a bit rich now... or so it seems by reading the plugs... this will be fun, but not a real test of ram air on the road...
Reload this Page A/O ram air install...
Tags
air, c4, corvette, front, license, ram
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FAST lsx install and thoughts SpinMonster C6 Tech/Performance 9 08-27-2005 09:00 PM
Cam OK to run w/o tuning? SJTrance C5 Tech 13 03-29-2005 12:45 AM
Help with throttle body install... Smokin Joe C5 Tech 15 02-06-2003 08:52 PM
Heads and Cam w/o Headers?? Ben01C5 C5 Tech 12 02-05-2003 06:42 PM
Tornado Air Management System vette_dreamer C4 Tech/Performance 24 01-21-2003 02:25 PM
HAMBO-MOBILE is getting started? TCC5 Great Lakes 20 01-29-2002 01:13 PM
Test drove the LG Motorsports G7 7.0l! Godspeed C5 Tech 29 12-22-2001 05:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
