Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-07-2004, 09:16 AM   #1
Ronnie_W
CF Senior Member
Default ford 9"
Is there a kit to convert the C4 from IRS to a Ford 9" or will it all have to be a custom build?
Ronnie_W is offline   Reply With Quote
Old 05-07-2004, 02:12 PM   #2
Thumper
CF Senior Member
Cruise-In II Veteran
Thumper's Avatar
Default Re: ford 9" (Ronnie_W)
It will have to be custom build. I know of two people who have put a solid axle in theirs and they both had to do some hacking to get it in.
Thumper is offline   Reply With Quote
Old 05-12-2004, 04:51 AM   #3
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
Default Re: ford 9" (Thumper)
IF YOUR CORVETTE IS A 94 OR NEWER ITS NOT AS BAD BECAUSE THAT YEAR FORWARD HAS A FRAME TO ATTACH THE CLIP TO.
REDC4CORVETTE is offline   Reply With Quote
Old 05-12-2004, 08:53 AM   #4
Ronnie_W
CF Senior Member
Default Re: ford 9" (REDC4CORVETTE)
The one I'm considering do it to is an 89.
What are the rules for how fast you can run at the track and still use the IRS? I see a lot of people running 9s and 10s with them. I also know 2 people that ran 10s and 11s at Gaineville Fl and were told that they had to go to a straight axle.
Old 05-19-2004, 05:57 AM   #5
REDC4CORVETTE
CF Senior Member
The NHRA RULE BOOK calls for drive shaft loops at 12.99 thats about all.to turn 10s 11s 12s you also need a 6 point roll bar, 5 point harness that is only good for about 3 years.
Old 05-19-2004, 01:36 PM   #6
jburnett
CF Senior Member
jburnett's Avatar
Send a message via AIM to jburnett
Actually NHRA factors the C4's IRS differently than they do the earlier IRS suspensions. I spoke at length a couple of years ago with Wesley Roberson (the head NHRA tech) when I broke into the 9's with mine. They are a "positive retention" setup unlike the previous IRS's which means the wheel won't come off should you break a halfshaft.
Regarding a 4-link or ladder bar setup for a solid axle swap it's really NOT that difficult but you do have to cut up the car from the rear bulkhead (behind the seats) back. I don't know what is meant by the '94 ups having a frame to attach it to but ALL Vettes have a real full frame (unlike unibody cars) and I don't believe the frame was changed at all between 1984 and 1996. You simply have to weld a ladder bar or 4-link crossmember to the frame and a secondary member for the coil over shocks that will be required. I've looked at several converted solid axle setups; one of which is Bob Curran's PRO Xtreme Street "Skunk" which is a ladder bar car. Believe it or not but it's NOT that difficult, it's just most people don't wanna cut out the rear floor of the car to do it.
I've been working with my chassis builder on coming up with a solution that would allow the stock control arm forward mounting locations to be used and the axle brackets to be on the rear of the axle instead of the front like a typical convention 4-link is. That would give you longer length bars and establish the instant center where it needs to be.
-Jeb
jburnett is offline   Reply With Quote
Old 05-20-2004, 10:58 AM   #7
Ronnie_W
CF Senior Member
Default Re: ford 9" (jburnett)
Thanks Jeb for the reply. Does this mean that the C4 IRS is okay for the 9s? I may try to do the 9" myself one of these days.
Old 05-20-2004, 01:58 PM   #8
jburnett
CF Senior Member
jburnett's Avatar
According to Wesley they don't have a factored ET for the C4's... The ET for the earlier IRS Vettes is 10.99 before a rear end swap becomes necessary. I've run 9.90's at several NHRA sanctioned tracks in my car (mostly Memphis) and never had anything said to me about the rear.. My 6 pt. cage was a different story... As soon as I broke into the 9's they told me I had to add a halo bar and downbars...
-Jeb
Reload this Page ford 9"
Tags
bar, c4, corvette, ladder
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4/Ford 9" project finished tpi 421 vette C4 Tech/Performance 41 03-03-2005 03:56 PM
Decided to go witn 12-bolt IRS setup instead of the Ford 9 inch... GrandSportC3 C3 Tech/Performance 42 01-08-2005 10:47 PM
C4/Ford 9" 4 link project tpi 421 vette C4 Tech/Performance 20 01-07-2005 12:57 PM
Ford 9 inch question... GrandSportC3 Drag Racing 21 04-24-2004 12:35 AM
Ford 9" rear for C4's found!!!! 1991Z07 Drag Racing 12 02-20-2004 09:01 PM
Ford 9 inch in a Corvette? John Dirks C3 Tech/Performance 24 04-04-2003 08:54 PM
Started Ford 9" Solid Axle 4-link project and TH350 from 700R4. easy! CarbedC4 Engine Mods 12 11-03-2001 03:49 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
