Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-02-2004, 09:25 PM   #1
Bruce
CF Senior Member
Bruce's Avatar
Send a message via AIM to Bruce
Default Finally my car is drivable
Over the last 3 weeks I have been working and waiting for special order parts for slave cylinder, and master cylinder. It thing are nightmare to bleed them. I bled the crap out of it yesterday, it has good pedal pressure . it still did not work. So I was tired and let it sit over night. Today I try to pump the clutch pedal again just to see what happen. I was about to pull the trany out next week. So I try to pump the pedal again and again. Thats sucker finally working and let me shift in gear.
I took the car out filled up some 93 octane gas and test drive the car. I gave a WOT to 3100rpm I see 5-6psi of boost and it spin the tires at 45mph at 3rd gear. That thing is pulling like crazy. Even though my car is not tuned for the 383LT1 stroker. I still using my old 350ci head/cam tune. Also my aeromotive FPR is awsome. my base fuel pressure set at 50psi when I go into WOT it rise the fuel pressure to 60-65psi because it is boost referenced
Man, after many hour of work on the car every weekend since the Winter. I am finally happy and my cogged setup performing to my satisfaction. No vibration what so ever.
I gotta make a new appointment with Shalin to tune my car again. My last appointment with was cancelled due to my clutch slave/master problems.
PS hopefully I will receive my 200hp jet from TByrne Motorsport before going to see Shalin.
Bruce
[Modified by Bruce, 7:35 PM 5/2/2004]
Bruce is offline   Reply With Quote
Old 05-02-2004, 10:00 PM   #2
TONYDEE64
CF Senior Member
TONYDEE64's Avatar
Default Re: Finally my car is drivable (Bruce)
Awesome Bruce!!!!! We want to see some video!!!!!!!
TONYDEE64 is offline   Reply With Quote
Old 05-02-2004, 10:14 PM   #3
Bruce
CF Senior Member
Bruce's Avatar
Default Re: Finally my car is drivable (TONYDEE64)
Hi Tony
How is your ride coming along?? I really want to see some hp# on your monster blown motor.
I will definately doing some video on the dyno. I have been driving my car last yrs with the Junk ATI 6rib serpentine drive setup. I cannot tell how a supercharged car feel like because it was not able to make boost and hold there.
Now I got a cogged setup and the belt can no longer be slip when I go in WOT I will see boost. Now I know a high hp supercharged car are can be very dangerious if you are not carefull. I was only at 3100rpm under boost 5-6psi all the sudden the tires broke loose. Can you a magine if the car are tuned and you shift it at 6000rpm under a load of hp and release the clutch.
Bruce
Old 05-02-2004, 11:27 PM   #4
TONYDEE64
CF Senior Member
TONYDEE64's Avatar
Hi Bruce.. no radiator for me yet...
I'd love to see some pictures of your cog set up.. I'm probably headed that way as well.. Do you have two separate belts, or did you get a cog pulley on all of your accessories...? Can't wait to see it on the dyno..!!!!
Old 05-02-2004, 11:35 PM   #5
Bruce
CF Senior Member
Bruce's Avatar
Tony
I use 2 belts. The cog belt is strictly for the blower by itself and the factory serpentine remain the same. Here is a pic of cogged balancer with 6 groove to drive the factory 6 rib serpentine belt.
Old 05-03-2004, 02:44 AM   #6
BAM92
CF Senior Member
BAM92's Avatar
I bet you have to have perfect alignment for your blower and balancer to keep that cogged belt from walking around. Does the blower pulley have sides on it or is just like the balancer in the picture?
BAM92 is offline   Reply With Quote
Old 05-03-2004, 07:04 AM   #7
Bruce
CF Senior Member
Bruce's Avatar
Default Re: Finally my car is drivable (BAM92)
BAM92
My idler pulley have both flange as guide and tendioner pulley have 1 flange for easy to get the belt on.
Bruce
Old 05-03-2004, 11:30 PM   #8
TONYDEE64
CF Senior Member
TONYDEE64's Avatar
That's a good looking pulley Bruce!!!!!! Did you make that... cutting those cog teeth isn't easy... Is that an actual balancer or a solid hunk of aluminum? Looks real good...!!!!!
Old 05-04-2004, 01:06 AM   #9
Bruce
CF Senior Member
Bruce's Avatar
Tony
it is made out of T7075 billet aluminum, it is extremely light and is very strong material. I did not make it all on my own. It involved a few people that helped me., Programming the CNC machine and grind a custom tooling to cut the teeth. The balancer is made on a big MAZACk CNC machine. Cutting the teeth is a mess because of coolant. It was done on the manual milling machine. If it is done the CNC milling machine than it would be easyto do. But in no way I can get time for the CNC milling machine to do it for me. because they always have job are running all the time.
Bruce
Old 05-04-2004, 01:39 AM   #10
XTwinTurbo
CF Senior Member
XTwinTurbo's Avatar
Man Bruce, I can't twist your arm to start a small production of those pulleys / cog setups could I?
I'd love to get a set made but I don't have the aptitude or machine shop contacts to get it done. Even throwing money at it may not helpful.
Would bringing the CAD drawings into a machine shop help or would I still need to understand them to direct the shop?
XTwinTurbo is offline   Reply With Quote
Old 05-04-2004, 08:31 AM   #11
Hammer
CF Senior Member
Support Corvetteforum!
Hammer's Avatar
glad it's back on the road, good luck with the tune/dyno.
Hammer is offline   Reply With Quote
Old 05-04-2004, 03:51 PM   #12
Bruce
CF Senior Member
Bruce's Avatar
Default Re: Finally my car is drivable (XTwinTurbo)
Honestly, I have no desire to go thru that again. Because I have to rely on few people that is involve in making it. If I could do it all on my own, than I probably would make batch of it. Sorry.
If you are seriously interested, you can contact TJWong. You gotta understand it is not gonna be cheap to make it.
Bruce
Old 05-04-2004, 10:17 PM   #13
zelement
CF Senior Member
Send a message via AIM to zelement
Have you hit the nitrous yet?
zelement is offline   Reply With Quote
Old 05-05-2004, 01:20 PM   #14
krivera
CF Senior Member
krivera's Avatar
Send a message via AIM to krivera
Bruce...
Where did you get that cog/factory belt setup? that is sweet! i want one!
krivera is offline   Reply With Quote
Old 05-05-2004, 03:46 PM   #15
Bruce
CF Senior Member
Bruce's Avatar
Default Re: Finally my car is drivable (krivera)
Kevin
My cog belt is off 1984-1988 Toyota/Celica supra timeing belt.
TJWong 's cog belt is off a 1990 Toyota camry.
Bruce
Reload this Page Finally my car is drivable
Tags
car, drivable
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A Corvette Horror Story-A GM Tragedy #1 champ_85 C6 Corvette General Discussion 123 07-08-2005 12:11 AM
Finally my 383 LT4 SR engine is done! ericcer C4 Tech/Performance 29 10-08-2004 09:57 AM
427 is up an running!!!!!! (VERY LONG) LOOKN2GETSTROKED C5 Tech 24 11-10-2003 12:42 PM
Heads / Cam....Finally decided to pull the trigger... here is my combo..... Shriker C4 Tech/Performance 26 10-28-2003 04:55 PM
Crossfire engine to Carb. Is it possible??????????? vettespd20 C4 Tech/Performance 14 05-07-2003 10:08 AM
Merlins car on ebay?!? ZD75blue C3 Tech/Performance 80 01-28-2003 12:18 PM
Is a modified, 500+hp C5 reliable and "streetable"? flipm C5 Tech 39 02-14-2002 10:50 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
