Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-26-2004, 07:29 PM   #1
mn_vette
CF Senior Member
mn_vette's Avatar
Default Timing for Octane
So you are supose to run the lowest octane that keeps your car from getting knock retard, but what about this. Is there a proper tune for different octanes? Can I tune my car to run on 92 octane then retard the timing X degrees and have it run just as well on 87 octane? Is there any reason to run the higher octane on a N/A, Nitrous, or FI motor?
Thr reason I'm asking is because I'm starting to mess with my timing on my car and I'd like to know if there is a theroy(sp? mental block) to tuning with different types of gas and see if I can save myself a few bucks the pump this summer. 9.5:1 compression just to let ya know.
I hope to get some interesting thoughts on this subject.
mn_vette is offline   Reply With Quote
Old 04-27-2004, 10:54 PM   #2
mn_vette
CF Senior Member
mn_vette's Avatar
Default Re: Timing for Octane (mn_vette)
TTT - nobody has any thoughts or expertiese on this matter??? I'm like atleast an educated guess from you guys before I go blow up my engine
Old 04-27-2004, 11:23 PM   #3
lcvette
CF Senior Member
lcvette's Avatar
Send a message via AIM to lcvette
MN,
octane plays a key role in how the car will perform with different tunes. to answer your question, yes you can tune per the different fuels available in your area.. once you finish the turbo project and have everything working properly you will also be able to adjust it for race fuel to run higher boosts and more timing. just like the gN guys.. they generally will have a "thumbwheel" chip which has about 5 tunes on it, some for different octane and boost settings. NA cars can also benefit from this.. generally speaking, with your compression ration and depending on your quench area and how your engine behaves in general, you can tune to the max for each octane fuel and run on the edge of detonation with proper fueling and make max power. so to answer your question... your on the correct path!
Chris
lcvette is offline   Reply With Quote
Old 04-28-2004, 10:15 PM   #4
GlockLT4
CF Senior Member
GlockLT4's Avatar
Send a message via AIM to GlockLT4
Default Re: Timing for Octane (lcvette)
If you're getting knock .. stick some 110octane in there and see if it goes away. If not, then you're getting false knock. If it does go away, add in more gas (87-93) and experiment with your overall octane rating ( simple(X+Y) / 2) until you get to where it causes knock again. Go back one octane level. This should (of course) be done with your highest performance timing.
I had to run 97octane in the 383 (had my timing too far in the hot Texas Summer).
[Modified by GlockLT4, 8:17 PM 4/28/2004]
GlockLT4 is offline   Reply With Quote
Old 04-29-2004, 09:26 AM   #5
mn_vette
CF Senior Member
mn_vette's Avatar
Default Re: Timing for Octane (GlockLT4)
Glock, how do you detect knock? Is there an easy way without having to buy a whole nother scan software setup? I'm running an aftermarket ECU that takes up the laptop and the serial port. I'd really like to not have to have two laptops to tune it right.
Old 04-29-2004, 11:11 AM   #6
GlockLT4
CF Senior Member
GlockLT4's Avatar
I use my laptop with DataMaster software. Does your aftermarket ECU require different software than normal?
Old 05-01-2004, 09:42 AM   #7
mn_vette
CF Senior Member
mn_vette's Avatar
I'm running an Accel DFI Gen 7. I has an input for a knock sensor but you need a special converter box and such for it, not cheap.
Reload this Page Timing for Octane
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Dark Side of Performance Timing Tele_Man C3 Tech/Performance 106 08-05-2005 03:29 PM
Timing technique-which do you do? Techno C3 Tech/Performance 18 07-22-2005 11:03 AM
Ok... I tried 89 instead if 91 octane.... AtHomeSoda C5 Tech 50 11-19-2003 06:51 PM
My car's at MMS for the 427 C5R, ATI D-1...... HIGHRPM C5 Tech 59 09-04-2002 09:46 PM
LARS: TOTAL TIMING FOR BIGBLOCK MELVIN C3 Tech/Performance 21 10-18-2001 03:49 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
