Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-08-2004, 12:37 AM   #1
marks350
Junior Member
Default Need help with boost and fuel gauge install
I completed the procharger install on my 86 and I have a gauge question. I bought the duel pillar mount and digital gauges to match the stock look. Where do you tap in the sending units????????
:confused:
marks350 is offline   Reply With Quote
Old 02-11-2004, 05:29 PM   #2
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Default Re: Need help with boost and fuel gauge install (marks350)
Hi Mark,
Most people mount he fuel sensor on the schrader valve on the fuel rail. Mine is mechanical It comes off the schrader valve and I run it to a transducer that converts from fuel pressure and has glycol on the other side of the transducer to keep fuel out of the driving area and controls the guage. If it is electronic you would essentially do the same thing the difference is you would run wires rather than a "fuel" line...
The boost guage I run off the passenger side vaccum I tee it off where the fuel pressure vacuum line connects. That is also where vortech sugests puttlling vacuum for the bypass valve. I have the dual pod as well...
Mo
Mo_Bandy is offline   Reply With Quote
Old 02-11-2004, 11:40 PM   #3
marks350
Junior Member
Default Re: Need help with boost and fuel gauge install (Mo_Bandy)
Thanks. Now for the next issue. The adapter I ordered from summit for the fuel gauge is the wrong thread to tap into my fuel rail. Summit's been great in the past but were stumped with this one. It's not a 1/16 NPT like they show. When you unscrew the schrader the threads are course.......??? I'll have to make some calls to the gauge companies , jegs, GM, NOS tomorrow to see if I can find out what the threads are. Or if they make an adapter that fits right onto the schrader without removing it. Now for the other problem. The digital electronic boost gauge sending unit has to be grounded to the motor through the threads of the sending unit. It only has a sending wire, so I can't tap into the hose....... The gauges are more trouble then installing the supercharger. :confused:
Old 02-12-2004, 01:06 PM   #4
85 Stalker
CF Senior Member
85 Stalker's Avatar
I agree!!!!!!!!!!! With all the gauges I needed to control the blower, I was more than nervous tearing into the systems (trans, fuel, block, etc...)
Of course, after researching what needed to be done, I took the cowards way out and had it done :lol:
85 Stalker is offline   Reply With Quote
Reload this Page Need help with boost and fuel gauge install
Tags
boost, fuel, gauge, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
Need help with gauge quality.... Which one? MyBlueC5 C5 Forced Induction/Nitrous 14 11-23-2004 10:29 PM
Class Action Suit against ATI !! Herb C4 Forced Induction/Nitrous 21 10-12-2004 12:13 AM
Magnuson back from Cartek....this thing is unreal!!!!!!!! 99C5ragtop C5 Forced Induction/Nitrous 44 06-28-2003 08:30 PM
FS - Procharger Kit for 1990-1991 C4 Mike in Boston C4 Parts for Sale/Wanted 22 12-27-2002 07:22 PM
Vortech on order 7LitreC5 C5 Forced Induction/Nitrous 53 11-21-2002 01:34 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
