Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-05-2004, 06:27 PM   #1
faj
Junior Member
Send a message via ICQ to faj
Default Good cam for supercharged L98?
Hello
Looking for a good cam for my 6psi procharged L98. Mods are: mildly ported D-port aluminium heads, modified LT1 intake, hooker headers and some other small stuff.
I'm looking at this COMP roller cam: (CCA-08-306-8)
* Advertised duration: 290 intake/307 exhaust
* Duration at .050 in. cam lift: 230 intake/244 exhaust
* Gross valve lift: .510 in. intake/.540 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 2,000 to 6,000
* Good in factory roller cam engines with TPI
* Modified computer, intake plenum, intake runners, and 2,500 stall
I'm sure it's a good N/A cam, but will it work good under boost?
Really appreciate your comments and thoughts!
(Emission is not a problem, just looking for performance)
faj is offline   Reply With Quote
Old 02-06-2004, 08:23 PM   #2
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Default Re: Good cam for supercharged L98? (faj)
That is the tried and true CC 306 grind. It is very lumpy and in my opinion wound not be a good blower grind. A better cam would be a LPE/Accel blower cam part number 74220, it has 215/220 duration at .050 on a 114 LSA. Lift is .530/.530 with 1.6 rockers. With the CC306 cam you would bleed a lot of your static compression away, not to mention the problem of tuning it to run right will be a PITA.
The LPE 74220 would be my choice with your combination as it is or a similar Comp grind.
tjwong is offline   Reply With Quote
Old 02-06-2004, 10:16 PM   #3
Haloe Ted
CF Member
Haloe Ted's Avatar
Default Re: Good cam for supercharged L98? (tjwong)
har du sökt efter gammla inlägg???
Detta ämne har diskuterats för på forumet... :)
Haloe Ted is offline   Reply With Quote
Old 02-06-2004, 10:18 PM   #4
Haloe Ted
CF Member
Haloe Ted's Avatar
Default Re: Good cam for supercharged L98? (Haloe Ted)
It didn't work on swedish, who would have known... I was trying too tell you too search the archives this subjekt has been discussed before on this forum...
[Modified by Haloe Ted, 5:36 AM 2/8/2004]
[Modified by Haloe Ted, 5:37 AM 2/8/2004]
Old 02-08-2004, 05:48 AM   #5
faj
Junior Member
How about this one?
http://catbox.junkshop.nu/~faj/slask...er/compcam.jpg
[Modified by faj, 9:48 AM 2/8/2004]
Old 02-08-2004, 07:29 AM   #6
Haloe Ted
CF Member
Haloe Ted's Avatar
I guess you already know what my response too this question is. :lol:
Hopefully som of the knowledgeble (damn hard word don't know the spelling of this one)gentlemen will chime in... :) :blueangel:
:grouphug:
[Modified by Haloe Ted, 5:30 AM 2/8/2004]
[Modified by Haloe Ted, 6:32 AM 2/8/2004]
Reload this Page Good cam for supercharged L98?
Tags
haloeted
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Superram, Mini ram with stock cam QuickGlass C4 Tech/Performance 10 03-15-2005 02:47 PM
Is this a good cam or what ? chillcat C4 Tech/Performance 19 02-14-2005 10:30 PM
Camshaft for blown L98?? Haloe Ted C4 Forced Induction/Nitrous 10 12-26-2003 11:29 AM
L98 buildup just went from mild to monster!! gsvette C4 Tech/Performance 23 09-19-2002 10:06 PM
Talk me out of it......anyone? Red85 C4 Tech/Performance 15 01-01-2002 05:12 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
