Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-05-2004, 05:38 PM   #1
Flame Red
CF Senior Member
Flame Red's Avatar
Default Here is a good supplier for SC hoses
Just wanted to post that I had my second good experience with these folks. First time I needed 4" tubing to relocate the air filter for my ATI. Now I needed to get a longer tube for the intercooler when I changed hose routing.
http://www.racerpartswholesale.com/duct.htm
I went with the silicone stuff. Holds up really well. Not cheap, but will give you enough to last a life time.
I know people have said that you can get this stuff at tractor trailer repair centers, but the ones around me just give me blank stares.
Flame Red is offline   Reply With Quote
Old 02-06-2004, 11:36 PM   #2
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Default Re: Here is a good supplier for SC hoses (Flame Red)
Does it kink if you flatten it out alittle? The stuff looks easy to run! Thanks for the link.
ANTI VENOM is offline   Reply With Quote
Old 02-07-2004, 08:29 PM   #3
Flame Red
CF Senior Member
Flame Red's Avatar
Default Re: Here is a good supplier for SC hoses (ANTI VENOM)
Anti,
No, it does not seem to kink. Has an internal wire that keeps it shape. You can pull the wire out and bend the end so it will not puncture the tube. Then it is easy to slip on and clamp down. Seems like tought stuff. Definately resistent to heat too. Easy to snake around tight quarters. Much better flexibility than the stuff ATI supplies. Pretty abrashion resistant, but if it rubs against anything sharp it will cut it.
Old 02-09-2004, 12:52 PM   #4
vvv90
CF Senior Member
vvv90's Avatar
What kind of clamps are you using on this stuff???
THe wires on the ducting look like it would prevent the clamps from being easy to work with.
vvv90 is online now   Reply With Quote
Old 02-09-2004, 04:12 PM   #5
Flame Red
CF Senior Member
Flame Red's Avatar
Default Re: Here is a good supplier for SC hoses (vvv90)
I used regular screw clamps. This wire in this hose can be pulled out and cut, leaving you a section as large as you want that is just hose. Then it is easy to snug down.
When you cut the wire, bend it into a small loop so that the sharpe end will not tear the hose.
Old 02-09-2004, 04:15 PM   #6
vvv90
CF Senior Member
vvv90's Avatar
aaaaah, I got ya :thumbs:
Old 02-16-2004, 12:41 AM   #7
Justme
CF Member
Justme's Avatar
Send a message via AIM to Justme
Is it smooth on the inside or can you feel the wires? Just wondering if it was enough to cause any turbulence in the air flow or not?
Justme is offline   Reply With Quote
Old 02-16-2004, 09:11 AM   #8
Flame Red
CF Senior Member
Flame Red's Avatar
Default Re: Here is a good supplier for SC hoses (Justme)
The wires are exposed internally, so they can be easily removed to get the host ends over the fittings.
Reload this Page Here is a good supplier for SC hoses
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
