Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-02-2004, 07:56 PM   #1
DREGSZ
CF Senior Member
DREGSZ's Avatar
Default What is Necessary Octane for 12:1cr?
Hi All, I know this isn't a Forced induction Question, but ya'll on this forum are quick and sharp.
What is the correct octane needed for a 12:1 race motor, solid flat tappet, with 750 carb, run at sea level?
I just put in 110 leaded because it all costs the same at the track, but what is the minimum Octane that should go in this motor/
THanks
Evan
DREGSZ is offline   Reply With Quote
Old 02-02-2004, 09:37 PM   #2
Rkreigh
CF Senior Member
Default Re: What is Necessary Octane for 12:1cr? (Evan Ginsberg)
110 should be enough. need info on what heads, cam, rear gears, ect...
all those variables affect what octane the car will need. more octane than needed will lighten your wallet but not make more power.
with a carb, as with efi, you need to have the a/f and timing right on to run big compression. chamber shape, quench, alot of things impact what octane will be need to make max power.
sounds like a fun ride. :jester
Rkreigh is offline   Reply With Quote
Old 02-02-2004, 09:51 PM   #3
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Default Re: What is Necessary Octane for 12:1cr? (Rkreigh)
Yes, we need lots of detail as stated above. I figured I could run 12:1 with fuel injection on an LT1 with the right cam on pump fuel. Anyway, cam, and rod length play apart, so give up the details.
ANTI VENOM is offline   Reply With Quote
Old 02-03-2004, 12:42 PM   #4
Brand-X
CF Senior Member
Default Re: What is Necessary Octane for 12:1cr? (ANTI VENOM)
ditto above...cam will determine dynamic cr.
Brand-X is offline   Reply With Quote
Old 02-03-2004, 10:29 PM   #5
DREGSZ
CF Senior Member
DREGSZ's Avatar
Default Re: What is Necessary Octane for 12:1cr? (Brand-X)
Hi All,
Sorry to keep you waiting on the vitals.
I run 110 because it is there at the same price, but I just found a cheaper source for 100 octane so I'm trying to find out what is the minimum I need, in case I can get by with less then 110.
The cam is a flat tappet, solid lifter Crower Circle track cam. PN 0350. I'd have to check the Cam Card to find out the lift.
I have Prolightning 220 heads with custom CNC 66cc chambers.
6.2" rods, big valves, 1.5 Rockers
Let me check what other info was needed
Old 02-27-2004, 11:45 AM   #6
1996man
CF Senior Member
1996man's Avatar
Send a message via AIM to 1996man
ttt :lurk:
1996man is offline   Reply With Quote
Old 02-28-2004, 07:59 PM   #7
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
check the cam card and tell us what the LSA is and the duration at .050 for in/ex. That will get us started. I would fill it up with that 100 octane and see if you get any detonation. If you do, have a can of 104+ to throw in. That will tell you if you can get away with 100. Just a though.
Reload this Page What is Necessary Octane for 12:1cr?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
