Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-26-2004, 07:35 PM   #1
autotech
CF Senior Member
autotech's Avatar
Default Blower vs MAF?
How does a Procharger Supercharger tie in to the intake system with the Mass Airflow Sensor taken into consideration? And, how is the additional fuel supplied? This is on an 88 C4...
autotech is offline   Reply With Quote
Old 01-27-2004, 01:33 AM   #2
BAM92
CF Senior Member
BAM92's Avatar
Default Re: Blower vs MAF? (autotech)
Carrol's Vortech kits blow through, Vortech pulls through, but I don't know about Procharger. I believe(some one will chime in and probably correct me) the best way is to blow through( Maf between s/c and tb).
BAM92 is offline   Reply With Quote
Old 01-27-2004, 06:17 AM   #3
neat
CF Senior Member
Send a message via AIM to neat Send a message via MSN to neat
Default Re: Blower vs MAF? (BAM92)
Blowing through the MAF equates to better WOT performance (assuming the ECM can sample fast enough), but it can be tricky to make idle well. Draw through idles well, but requires a better tune for WOT performance.
neat is offline   Reply With Quote
Old 01-27-2004, 03:15 PM   #4
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Most MAF systems will have the MAF Sensor placed between the blower intake and teh air filter. Also there has to be a bypass valve plumbed in to releive compressor surge when the engine is decellerating from a high speed. This bypass when a MAF is used has to be located between the MAF and the blower intake. As this is air that is already been measured by the MAF sensor.
I don't really think it matters which location that the MAF will be located in. Either way the air volume or mass will be measured either at the suction or at the discharge it will be the same.
For fuel enrichment, most blower systems vendors tend to use a FMU. Or what is commonly known as a Fuel Management Unit. This device is connected in series with the fuel return line to the OEM pressure regulator. And usually it has a ratio of 10:1 which means that for every pound of boost pressure the FMU will raise the fuel pressure 10 PSI. While this system works for most stock applications with low boost of 6 or 8 PSI. The better way is to map the fuel enrichment in the PCM. Which would take either a custom program or a person purchases his own tuning software and does it himself. The best way is to map the fuel curves on a chassis dyno where real time data can be analyzed to make the correct fuel map changes.
tjwong is offline   Reply With Quote
Reload this Page Blower vs MAF?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Halltech's C6 Stinger SSM--It Rocks CAU-LLC C6 Tech/Performance 133 09-17-2005 09:54 AM
MAF flow vs HP MSR C4 Scan & Tune 15 03-09-2004 01:17 AM
LPE TT Stage 1 vs. LPE I/C Mag blower + heads vs. C5R Stroker + nitrous WA 2 FST C5 Forced Induction/Nitrous 26 10-24-2003 01:07 PM
Do we want to .be slightly rich with a blower? Jim Shearer C5 Forced Induction/Nitrous 11 03-05-2003 01:01 AM
Lt4+boost vs. LT1 + boost (SC) Lone Ranger C4 Tech/Performance 10 01-23-2003 07:55 AM
Don't Believe the Myths! Hand Ported vs CNC heads Mike Morgan C5 Tech 35 08-10-2002 01:12 AM
1/4 mile: stock Corvette vs stock Cobra, who wins? Driller C5 Tech 37 04-01-2002 09:10 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
