Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-26-2004, 03:26 PM   #1
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Default Turbo exhaust flange and pipe questions.
My turbo has a 3" outlet I.D. and is a V-band clamp design. The outside is 3.5' and I don't know what size pipe to run or what clamp to buy. I want to keep back pressure low, so I thought maybe a 3.5 in pipe, but need to know if I will have to reduce it back to 3 in with a 3 in V-band clamp. If that makes sense, please leave me some info. I want to order soon and need help.
ANTI VENOM is offline   Reply With Quote
Old 01-26-2004, 03:55 PM   #2
mn_vette
CF Senior Member
mn_vette's Avatar
Default Re: Turbo exhaust flange and pipe questions. (ANTI VENOM)
is the v-clamp flange 1/4" thick? If you can weld the two togther then you should be fine, but getting an exhaust shop to make you a 3" to 3.25" piece shouldn't be a problem. You may have to get the 3" piece from somewhere though.
I was thinking of doing the same thing, and i'm going to try and just put the 3.5" over the v-band flange and weld it like so.
mn_vette is offline   Reply With Quote
Old 01-26-2004, 04:22 PM   #3
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Default Re: Turbo exhaust flange and pipe questions. (mn_vette)
After doing some more research, it seems that there is a v band "transition" flange that will do what I want, but I have only seen them in smaller sizes. Basically, it would be a 3" v band clamp with a flange that would go inside of the 3 1/2" pipe to step up the pipe size. That's how I saw it anyway. I could still use help.
Old 01-27-2004, 04:46 PM   #4
Baldturbofreak
CF Senior Member
Baldturbofreak's Avatar
Send a message via AIM to Baldturbofreak
There is a national chain Called "Fleet Pride" Look in your phone book. Take it down there, they have stuff like that in stock and you can just try one until it fits. They have transitions that have divergent cones from the turbine outlet on a nice smooth angle into 3.5" At least at the One near me. But any tractor trailer supply store should have what your looking for. :reddevil
Baldturbofreak is offline   Reply With Quote
Reload this Page Turbo exhaust flange and pipe questions.
Tags
exhaust, flange, fleetpride
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
