Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-17-2004, 01:22 AM   #1
DREGSZ
CF Senior Member
DREGSZ's Avatar
Default S/C on 12:1 motor with 110 race gas?
Hi all,
I'm thinking about ways to get more power for my race motor.
It is a destroker, 377, 12:1, forged bottom end with 220 Prolightning heads, and demon carb.
I run it on a full race '88 vette in various road race series here in CA.
Can I run a blower with 12:1 compression and 110 race gas safetly?
or am I doomed to detonation with 12:1 compression?
Evan
DREGSZ is offline   Reply With Quote
Old 01-17-2004, 10:14 AM   #2
AKS Racing
CF Senior Member
AKS Racing's Avatar
Default Re: S/C on 12:1 motor with 110 race gas? (Evan Ginsberg)
Doomed to detonanion, due to the high s.c.r. Best to purpose build the shortblock for the intended application. Are the heads aluminum? If not, the heads and carb will only add to the reasons why not to SC at this high s.c.r.
Aaron
AKS Racing is offline   Reply With Quote
Old 01-17-2004, 11:12 AM   #3
Baldturbofreak
CF Senior Member
Baldturbofreak's Avatar
Send a message via AIM to Baldturbofreak
Well, how do you/ your sanctioning race body feel about methanol? Most badass blown alcohol drag cars start with 11-1 or better then pump 20psi of screwcharger boost on it.
It's also may be possible to use vp116/intercooler/and water-methanol injection with low boost (under 6psi). MY first crack at the turbo setup was just a hair under 11-1 (hypereutectics!) with 7psi intercooled on pump gas. But only ONE mistake in the fuel curve spelled DOOM for this motor's ring lands
Baldturbofreak is offline   Reply With Quote
Old 01-17-2004, 11:22 AM   #4
Baldturbofreak
CF Senior Member
What is the rod length? how hard do you twist it? (rpm) Long rod high rpm motors don't have time to detonate. If you has it cammed to run from say 3500-7500+ rpm then it is feasable to run a low boost system. Remember, compression ration has a PROFOUND effect on how much BHP per CU/psi. That is the higher the compression (detonation aside) the more power you get from each pound of boost.
According to this calculator http://www.turbofast.com.au/TFcompB.html
with a 377, 12-1, 93% VE and 6 psi (non intercooled) it states that boost compression will be 15.4-1 and recommends 111 octane.
Old 01-17-2004, 03:42 PM   #5
DREGSZ
CF Senior Member
DREGSZ's Avatar
Default Re: S/C on 12:1 motor with 110 race gas? (Baldturbofreak)
This is a road race application for NASA Vette Viper Challenge.
Forced induction is allowed in the VX class.
I turn 5000-7500 rpm for 30 minutes solid all out, per sprint race. my rods are 6.2, Eagle H Beams, Eagle Crank and JE pistons, all forged. Pro Lightnig AL heads, 220 runners, 66 custom CNC chambers.
I don't think I can run more then 110 octane gas, addidives are unlikely.
I'm at or near sealevel for all but 2 races, (one at Reno, one at Fontana).
I expect I would need an intercooler for the demand I place on the motor.
Old 01-19-2004, 01:32 PM   #6
Baldturbofreak
CF Senior Member
An intercooled procharger (D1), plus a smg water injection kit would do well in your application. you must remember that boost goes up the square of rpm for centrifugal compressors, so some calculations for pulley size are in order for that kind of Rpm. keep boost below 7 psi with the water/methanol injection kicking in at 3-4 psi. That will keep you safely out of detonation even on the hottest days with 12-1.
Sounds like a screamin combo. the long rods will help out with octane tolerance (due to increased dwell time at TDC) as will you cnc'd alum heads.
You didn't mention cam specs, but I imagine a solid roller with some square lobes are in place :cheers: That will keep you from building much low speed cylinder pressure before boost comes on(at like 4500). Just take a look at your cam card for the lobe separation. 112-114 would be ideal to keep from losing to much out the exhaust. One of those knock sensor kits would be cheap insurance as well. :chevy
Old 01-21-2004, 07:25 PM   #7
BoostManiac
CF Senior Member
If you truly want to benefit from the extra cost, complexity, heat, and weight of a supercharger, you need to run more than 3-4 psi boost. You shouldn't be much beyond 10:1 even for relatively low boost applications IMO. Even that would be a case where you need to carefully limit boost, your compression ratio is effectively doubled with forced induction. Most FI production cars are more in the 9:1 range, which can allow very high boost with proper tuning.
BoostManiac is offline   Reply With Quote
Old 01-22-2004, 01:59 PM   #8
krivera
CF Senior Member
krivera's Avatar
Send a message via AIM to krivera
Default Re: S/C on 12:1 motor with 110 race gas? (BoostManiac)
ok i have a question...now i know a little about SC a EFI but what about a carb do you get splashing in the bowls in the carb how do you control that?
krivera is offline   Reply With Quote
Old 01-24-2004, 10:19 AM   #9
Baldturbofreak
CF Senior Member
Default Re: S/C on 12:1 motor with 110 race gas? (krivera)
Nope you put the whole carb in a pressure box. Vortech, ati both make one. Then fuel is boost referenced 1:1.
Reload this Page S/C on 12:1 motor with 110 race gas?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Any N/A Lt-1's making 500 rwhp? Kehrer923 C4 Tech/Performance 75 07-26-2005 01:54 AM
You CAN make big power with a Single Turbo on a C5 Earl H C5 Forced Induction/Nitrous 19 06-15-2004 10:11 PM
Dyno Blues - 427 - Time warp out of 1970! kaiserbud C3 Tech/Performance 45 07-26-2002 09:10 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
