Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-11-2004, 03:15 PM   #1
AKRAY4PLAY
CF Senior Member
Default blown small block combos??
hello all,
i am looking for some blown small block combos that work well in C4's. a friend of mine is looking at building a 350 or 383 with a 671 set-up. he is kind of on a budget and wants around 600 hp. i don't know jack about forced induction. if you can help me out with some combos that would be awesome. at this time he is looking to go carbed and maybe up grade to EFI next year, and best of all emissions is not an issue. thanks for the help in advance! Brian
AKRAY4PLAY is offline   Reply With Quote
Old 01-12-2004, 10:27 AM   #2
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Default Re: blown small block combos?? (AKRAY4PLAY)
Unfortunately, very few use roots style blowers on C4's due to the lack of hood clearance and the availability of centrifugal blower kits. I looked into a roots style, but never found a combo that I liked for use with fuel inj. I know that there was a guy on this forum that did use a 6-71 and got it running. If your friend wants the look of a roots style w/ carb sticking out of the hood, I won't try to sway him one way or the other, but if 600 hp is all he's looking for, there may be easier (not necessarily cheaper) ways.
ANTI VENOM is offline   Reply With Quote
Old 01-12-2004, 12:21 PM   #3
AKRAY4PLAY
CF Senior Member
Default Re: blown small block combos?? (ANTI VENOM)
i tried to talk him out of forced induction, or into a Whipple, but he's stuck on getting a whole cut in the hood. thanks for the reply, Brian
Old 01-12-2004, 12:54 PM   #4
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
If he is on a budget he could look at one of the smaller blowers like the weiand/holley 177. It readily accepts a single 4bbl and it could feed a small displacement engine. (350) He will also have to find a manifold/blower that will work on his heads. You didn't mention wich ones he has. L98 or LT-1. If this is to be a daily driver and your in Alaska, he may need a way to keep the rain out of the filter. Make sure he thinks this project through before cutting the hole! Good luck.
Reload this Page blown small block combos??
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
