Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-07-2004, 04:00 AM   #1
almostavette
Junior Member
Default best way to find the right blower cam?
I need some help finding a cam for this motor any help will be appriciated
my specs are
stroked 383 chevy 95 K-block hydrolic roller cam
SuperRam intake 1000CFM TB 42Lb Hr injectors
paxton SN2000 6-8 PSI intercooled
AFR 195 heads 8.5-1 comp
4l60-e trans with 2200 stall flashes at 1900-2000 on the street
373 rear gears with about 88 inch rollout or 275-50-17
wheighs 4300Lbs
was running comp part # 08-305-8 dur. @.050 220in. 230ex. lift is 510in 510 ex. and 114* lobe seperation and had more lowend than I need and just didn't hit the revs I wantit has all forged 4340 crank rods and JE pistons. this is a street truck but I don't care if it idles rough or is a little sluggish at low RPM. I spoke with somebody at comp and was told to run the 08-503-8 dur. @.050 224in. 230ex. lift is 503in 510 ex. and 112* lobe seperation does this cam look good? or is it worth the $250-300
almostavette is offline   Reply With Quote
Reload this Page best way to find the right blower cam?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Possible Z06 Price Drop? bluestreak63 C5 Z06 Discussion 68 01-18-2004 08:29 PM
Forged motor comp ratio??? xtream1 C5 Forced Induction/Nitrous 15 10-26-2003 01:06 PM
Porting the stock alu heads, words from my mech... devilfish C4 Tech/Performance 17 11-01-2002 02:13 PM
Are pushrod engines better than DOHC? Why? Ender85 C4 Tech/Performance 41 10-30-2002 05:23 PM
Anyone have any thoughts on the VaraRam intake? H-TownC5 C5 Tech 44 09-27-2002 05:15 PM
383 Dreamin' GRX C4 Tech/Performance 16 05-12-2002 11:59 AM
Got engine out for rebuild...now what?? Jughead C3 Tech/Performance 11 10-29-2001 12:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
