Could use a recommendation on Fuel System parts.
By fuel system I mean from the pump to the injectors and the computer also. From my signature at the bottom you can see what I have, the only change will be swapping a D1 for my P600b.
I know that injector size can be figured out pretty easily by just crunching the numbers and the same for pump size. More the issue is configuration, I was told the stock computer gives up at 500hp and the stock fuel system at around 550hp.
1. Do I use the stock fuel line now as the new return line.
2. Do I have to plumb a new pickup line into the tank in the new larger fuel line size. I have no clue how hard this is to do or if there is a kit that has a drop in section already done, which would be nice. I assume this would go through the existing removable section that has all the lines going through it.
3. Do I need to machine out the stock fuel rails or is there an aftermarket alternative. I have seen a number for hondas and fords, but not TPI engines.
4. Would the crossover need to be replaced with a larger steel braided unit. Boy I hope someone makes a pre done hi flow fuel rail kit.
5. Should I try to use some sort of in tank set up or just use one of the large inline pumps and filters available and mount it under the car. I am not sure any in tank ones can feed a D1 intercooled 406. Any recommendations on brand would be cool.
6. The Accel DFI Gen 7 seems to be a popular aftermarket computer, although at $1420 its painfully expensive. And the broadband 02 option adds another grand. Just how necessary is this? Does it require a laptop to run or is it stand alone?
7. Any recommendations as to pump and line size to feed this combo?
I am sure there are more things I am forgetting to ask but this should get me started. This part of the buildup has been making me apprehensive for quite a while. Because of all the variables and the knowledge that with FI engines the correct combination is the key to everything and having a badly mismatched component can mess up the whole system. Any recommendations and advice is most appreciated and I can start trying to overcome the fuel system monster I have been fearing for so long. Thanks much.
Re: Could use a recommendation on Fuel System parts. (Jaxian)
Re: Could use a recommendation on Fuel System parts. (vvv90)
Awesome response, thanks very much. Now I have some direction as to were to start. Was getting worried that no one would reply to it, heh. Thanks for biting the bullet and helping me out! :cheers:
Here are some pictures of my fuel mods under the hood. I simply ran a new 6an line from the tank and tied it into the system as shown.
Pic 1
Pic 2
Pic 3
Maybe it helps a little. You can also wire it to where the second pump is only on under a certain amount of boost. I just let mine both run all the time.
[edit] The image tags are screwing up - changed to url links.
[Modified by Vette92, 1:14 PM 10/14/2003]
Pic 1
Pic 2
Pic 3
Re: Could use a recommendation on Fuel System parts. (Vette92)
Pic 1
Pic 2
Pic 3
Pic 1
Pic 2
Pic 3
Does the stock return line handle everything ok??
How did you plum the sending unit on the tank??
Were there any other mods to the fuel rails?
Are you still running the stock FPR with a spring adjustment on it?
[Modified by mn_vette, 10:23 PM 10/14/2003]
[Modified by mn_vette, 10:26 PM 10/14/2003]
Re: Could use a recommendation on Fuel System parts. (mn_vette)
So basically you ran another feed to the pressure test port on the fuel rails and everything is good?? Does the stock return line handle everything ok?? How did you plum the sending unit on the tank??
Chris
Cool this info is helping alot as to what I can do to get the fuel system up to snuff. Sounds like the Racetronix GSS340M kit would be a good place to start but their website is a little short on info. It doesn't say how many Gallons Per Hour the pump moves or what type of HP level it can support. I searched on their webpage for a phone number or some way to contact them but can't find anything. They show the kits as being factory direct purchasable items, show the prices and the shipping, and that they take credit cards but they don't have a number to put in an order or ask questions. Odd. Maybe I am just missing it somewhere on the page. I guess I could call and talk to one of their distributors but I figure why bring in a middleman for a part the factory sells and should have the most reliable info on. The webpage doesn't even mention the Boost-a-pump thing, not sure what that is.
I have been talking to some people and keep getting different opinons on how much horsepower the stock fuel lines and rails can take. Numbers seem to be hitting from a low of 550 to upwards of 700. If its only 550 then my motor with the D1 will be in trouble at higher boost levels. So I am still trying to figure at what horsepower level I need to step up to bigger lines or rails. Actually I guess they might have different flow levels, like the rails can take 700hp stock, but the lines or pickup only 550hp. I will keep watching the boards and try to see the setups people with those power levels have that they have made work for their motors.
Thanks again for the help, it is giving me a lot of directions now to dig up some info and get this thing done right. I have like 15k into the motor without the blower and don't want to melt it.
The GSS340 and GSS307 pumps are both 255lph flow pumps. The difference is that the 340 pump flows fuel better than the 307 at higher fuel pressures (55+ psi). I am running 2 GSS340 pumps in mine.
FWIW, the stock 3/8" lines could probably feed up to 700 hp. The 550 hp limit is with the stock fuel pump. I just went with the extra pump because I wanted more of a dedicated pump to run the nitrous with. I tied it to the fuel rail as a safety measure and to take advantage of the stock return line and fuel pressure regulator.
I imitated my buddies 383 blower motor setup that was using pretty close to this same setup but he was using two stock pumps.
Chris
Chris
Do a search on the left for a user called "racetronix" he's the tech support guy and usually adds to the topics with great help. They're a top notch company. I don't know about info on the site but I've ordered from them direct. There should be an email to send to to also get more info on the "boost-a-pump"
As for the fuel rails, I don't know about the L98's, try contacting someone at http://www.tpis.com and pose the question to them.
:cheers:
:cheers:
Ok, I'm just thinking about this becuase I could probably sit down and do it tonight with the parts that I have.
I've got one Walbro in there already, what about taking my stock pump that I have left over and running that through a 4an line all the way to the fuel pressure test port. The big key being no fuel rail modifications.
If the stock pump supports 4-500 and the walbro supports 600 that should be an easy 900 hp fuel system. I'd leave the second fuel pump on a relay hooked to the nitrous arming switch.
Does this sound right or am I missing something. Given that both pumps would be at the same fuel pressure I would think this would be ok.
[Modified by mn_vette, 10:36 PM 10/15/2003]
The only problem that I see with it is that both pumps are feeding into the same fuel log and the second log is only being fed by the 3/8" crossover line at the back of the '92-93 fuel rails. I would think it would only benefit if the crossover was increased in size, but it may help overall if the first pump simply can not keep up with fuel demand. Not sure how much fuel you can flow through a 4an line.
Where are you getting the fuel for the nitrous, or are you running a dry system? I had an alterior motive in runnng the 6AN line as I did not trust the test port to flow enough fuel to feed the nitrous.
:confused: The big question I have is how do you plumb the second line through the top of the sending unit?? :confused: And how do you hook the wires to the fuel pump??
[Modified by mn_vette, 11:15 PM 10/15/2003]
Supporting Vendor
You should not mix two different pumps.
HP support is not cumulative for parallel pumps as pressure drop across the feedline increases with the volume demands.
A single in-tank GSS340M + Racetronix harness is good for 550RWHP+ (this is with a safety margin. We have seen well over 600RWHP).
If you order the series II harness with PnP pump booster interface (add BAP / MSD) it can support upwards of 700RWHP assuming normal operating pressures with properly sized injectors.
L98 rails have a balancing problem so a line should be added between the L & R rails.
For setups of this nature we recommend you contact More Performance as they stock the series II kits and can advise you on its high HP application.
Jack :cool:
Racetronix
Jack :cool:
Racetronix
Re: Could use a recommendation on Fuel System parts. (Racetronix)
Hey Jack, I've got a 396 putting ~450HP and I just ordered the jets for my 250HP shot-o-noz. That's about 700hp give or take, but to be on the safe side I'll stick with the dual pumps. And when/if I add the supercharger next year, I won't have to change it again(I did order a second walbor to match). Atleast not in the tank. Thanks for the info. :seeya
Jaxian, dude, sorry about hijacking the post. You got me thinking and excited. If I'm running 12.4 on motor, that 250 shot should get me very close to 10's. I just have everything overnighted and it should be ready for the track on sat. So we'll see.
[Modified by mn_vette, 9:26 PM 10/16/2003]
Re: Could use a recommendation on Fuel System parts. (steve40th)
Yes Steve, the GSS340 is a direct replacement for stock. The way I got two of them in there is with a simple band clamp that holds the new pump to the stock one. They both pull from the baffle inside the tank.
I do not know what that other part you mention is. I think it ups the voltage to the pump causing it to flow more, but I am not sure.
Is the GSS340 a Bolt in to the 93 Vette tank? Also, what is th ePnP booster with BAP/MSD?
all 255lph intank pumps are a direct replacement. The PnP ia plug N Play wiring harness. BAP= Boost A pump. Either kene Bell BAP od MSD BAP
Bruce
Bruce
