Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-30-2002, 05:06 PM   #1
scorp508
CF Senior Member
scorp508's Avatar
Default What fuel pressure is best for nitrous applications?
Once I get these leaking injectors or failed regulator squared away I'm hoping to start tuning the car. I'd like to set the pressure once and then leave it alone and just make changes in the chip down the road.
My question is does anybody know what fuel pressure NX estimates you to be running when you mount their fuel solenoid's feed line to the fuel rail?
scorp508 is offline   Reply With Quote
Old 10-30-2002, 06:31 PM   #2
SPD DMN
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
SPD DMN's Avatar
Default Re: What fuel pressure is best for nitrous applications? (scorp508)
I beleive that the NX pills for an LT1 are designed for 43.5 psi of fuel pressure. As you know, when you do your dyno testing, you can play with different fuel pressure to modify the air/fuel under juice, but I would start somewhere between 42-46 psi. The Camaro kits are supposed to be rated for 39psi.
Not sure which one your kit is rated for though. I guess an easy way to find out wouldbe to compare the recommended pills for the 100 shot. Mine is 52/33 for a 100 shot.
SPD DMN is offline   Reply With Quote
Old 10-30-2002, 06:51 PM   #3
scorp508
CF Senior Member
scorp508's Avatar
That is exactly what mine says for 100. This is kit...
Part#: 20920
"ALL" GM "STAGE ONE" EFI SINGLE NOZZLE SYSTEM (35-150 h.p)
The jet sheet has basically every GM engine except for an L98 on it. :lol: Anyone wanna know what to use for 75hp in a Bonneville? :D
Old 10-30-2002, 06:59 PM   #4
SPD DMN
CF Senior Member
Cruise-In I Veteran
SPD DMN's Avatar
Default Re: (scorp508)
At 43psi and 1050 psi bottle pressure, you should see close to 11.8-12:1 air/fuel on a dyno with those jets.
Chris
Old 10-31-2002, 02:18 PM   #5
scorp508
CF Senior Member
scorp508's Avatar
I had sent NX an email before making this post. They just got back to me saying that the system was setup for around 45psi. :)
Reload this Page What fuel pressure is best for nitrous applications?
Tags
applications, fuel, nitrous, pressure
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Long tube headers and shorty's...what's the difference? los7883 C5 Tech 21 06-28-2010 07:23 AM
TPIS,TTS,LG,ballenger headers and dyno results Phil97SVT C5 Tech 42 01-24-2002 03:31 PM
Interesting article on headers - long, but good read Paradigm C5 Tech 13 01-06-2002 07:41 PM
Why does back pressure affect torque??????? John Shiels C5 Tech 19 12-08-2001 12:22 PM
Fundementals of Exhaust Header Design... Bennefits and Ramifications kewlbrz C5 Tech 13 11-17-2001 01:19 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
