Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-30-2002, 04:59 AM   #1
Tomas
CF Senior Member
Tomas's Avatar
Default Custom chip and bigger injectors?
Hello
I have a small question. For the moment i have Accel 30lbs high impedance injectors with a custom chip burned for my injector size. What happens if I change to 55lbs low impedance injectors with the same chip that i have burned for 30lbs? Will it work? What happens?
thanks
regards
Tomas
Tomas is offline   Reply With Quote
Old 11-04-2002, 07:09 PM   #2
vvv90
CF Senior Member
vvv90's Avatar
Default Re: Custom chip and bigger injectors? (Tomas)
Not if you want to drive around with black smoke spewing out the back.
From the look of your setup though, you should be tweaking the computer for any change you do.
[Modified by vvv90, 4:10 PM 11/4/2002]
vvv90 is offline   Reply With Quote
Old 11-05-2002, 04:34 AM   #3
Tomas
CF Senior Member
Tomas's Avatar
Default Re: Custom chip and bigger injectors? (vvv90)
Hello vvv90
Lots of tuners has told me that I have too small injectors now. 30lbs will handle approx 500hp. I havent dyno my car but if calculate my ET/weight I has to have around 500hp. This winter i gonna tune my car more so thats why i gonna go for bigger injectors.
Old 11-05-2002, 05:11 AM   #4
Tomas
CF Senior Member
Tomas's Avatar
Will my stock ECU handle low impedance injectors?
Old 11-05-2002, 04:30 PM   #5
vvv90
CF Senior Member
vvv90's Avatar
go to http://www.tpis.com
Call them and ask, they won't steer you wrong. How much HP to you expect to be putting out though? I still think going from 30's to 55's is a pretty high jump. But you're absolutely right, it's all about the HP.
:cheers: :cheers: :cheers:
Old 11-06-2002, 02:38 AM   #6
Bruce
CF Senior Member
Bruce's Avatar
Send a message via AIM to Bruce
You can not run 55# injector it will burn up your ecm. Max is 50s for stock computer.
Bruce
Bruce is offline   Reply With Quote
Old 11-07-2002, 11:35 AM   #7
dgoodhue
CF Senior Member
dgoodhue's Avatar
Just looking quickly at your setup and time slip, it looks like your runing about 116 mph (this is 1/4 mile track, right?). This look to be around what a 383 SR run which is around 430-450hp. I think you need some more tuning as I would expect a 355 S/C would to make more power than a 383. You could probably use larger injectors than 30lb/hr, but your probably not running out of fuel yet with the FMU and the hp your making.
dgoodhue is offline   Reply With Quote
Old 11-07-2002, 12:16 PM   #8
vvv90
CF Senior Member
vvv90's Avatar
Default Re: Custom chip and bigger injectors? (dgoodhue)
You should also slap a D-1 on there and up the boost to about 20! :D :D
That should help too. However, after looking at your setup the only weak link I can see besides the U-joints maybe is your crank if it's stock. You should have no problem getting insane amounts of power with what you have already. What's your inevitable goal for that car?
:cheers: :cheers:
Old 11-07-2002, 04:37 PM   #9
Tomas
CF Senior Member
Tomas's Avatar
Hello vvv90
Unfortunately the crank is stock, but it is balanced. I have heard that a balanced stock crank is good for approx 650hp. My Goal next summer is low 11s. Just with new tires and good grip i think i can hit 11,50.
A new D1 blower should be nice so I can have more boost, because now I have the smallest pulley for 600b blower
regards
Tomas
Old 11-07-2002, 07:06 PM   #10
vvv90
CF Senior Member
vvv90's Avatar
cool. :cool:
Don't get me wrong, stock cranks are pretty strong. It was more or less a compliment, because if a stock crank that can take 650HP is your weakest link, you're definitely doing something right. I got the P1SC so that I can upgrade it to the D1 when I eventually reguild my bottom end. But that's still gonna run me $1000 to get it upgraded.
BTW: how many vettes do you see in Finland?
Old 11-08-2002, 04:53 AM   #11
Tomas
CF Senior Member
Tomas's Avatar
Hello vvv90
Im not really sure how many vettes there are in Finland, because im coming from an Island called Åland that belongs to Finland but we have our own laws, flag, stamp etc and we speaks swedish. On Åland there are 14 Corvettes. And that is quite good if you see how small our Island is.
regards
Tomas :lol: :yesnod: :seeya
Old 11-25-2002, 10:44 PM   #12
dsagers
CF Senior Member
dsagers's Avatar
Above answer is correct, you will fry the ECM.
Low impedance injectors are 3 to 4 ohms, the factory ECM and injetors are high impedance - 16 ohms.
Also, the low impedance are a peak and hold where the injectors receives a jolt of some 2 amps to open it and then the signal backs off to .5 amps to hold it open.
The factory stuff is a saturated system. High signal all the time, no peak & hold with the facoty stuff.
A couple options. One is to find an Accel VIC controller. This unit takes your factory injector signal and converts it to 8 low impedance, peak & hold signals. Plus each driver can be adjusted up to 25% to individually trim each cylinder.
Usually see them on ebay for around $300. For insatnce,
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1872718571
Next option is to use an additional injector controller. This unit will switch on additional injectors at a pre set RPM, load or boost.
The additional injectors are usually placed behind the throttle body blades and can use either the low or high impedance style, all depends on the system you buy.
HKS has very nice, but expensive ($800) tunable unit. Some of their older versions are more than adequate, just not as many features. Also, much less money to buy.
Another thing to keep in mind. Low impedance injectors respond faster than saturated injectors and have a much shorter minimum open time. This is the reason you can run 58 lbs/hr low impedance injectors on a small block without flooding the engine at idle.
If you put say, 42 bs/hr saturated injectors on a small block, it will be very rich at idle because the high impedance injector is rather slow compared to a low impedance injector.
dsagers is offline   Reply With Quote
Old 11-25-2002, 10:53 PM   #13
dsagers
CF Senior Member
dsagers's Avatar
Here is another option. Not as big as you want, but use an adjustable fuel pressure regulator and you will be close.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1873348405
Reload this Page Custom chip and bigger injectors?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
? about running Juice and TPI Mad-Mic C4 Forced Induction/Nitrous 20 08-28-2004 09:10 PM
383 strokers, what size injectors do you have? etc... w/in> *89x2* C4 Tech/Performance 13 02-12-2002 04:57 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
