Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-29-2002, 11:25 PM   #1
88-406
CF Senior Member
St. Jude Donor '05
88-406's Avatar
Send a message via AIM to 88-406 Send a message via Yahoo to 88-406
Default Attn: Brainstormers
I'm wondering what it would take to mount the P600B (L98 KIT) on the other side? Since I've totaly eliminated my AC system I'm wondering if it might make more sense to mount it over there?
Anyone have any thoughts about doing this? Has it been done before? What would be the biggest obstacle?
KM
88-406 is offline   Reply With Quote
Old 10-30-2002, 07:20 PM   #2
black bart
CF Senior Member
black bart's Avatar
Default Re: Attn: Brainstormers (88-406)
To mount it on the right side you have to rotate it 180 degrees this will point the outlet toward the engine but it will be on the bottom instead of on top so you will have to custom build all of the tubes. I'm building a custom tube setup for mine right now but for a different reason. That would be a lot of work for no gain in performance How about a P600 on both sides :D I thought about doing that but decided to keep the ac and go with a bigger blower on the left side it has to have larger tubes everthing must be custom made since the blower flows nearly twice what the P600 will. :cheers:
black bart is offline   Reply With Quote
Old 10-31-2002, 01:06 PM   #3
JoBy
CF Senior Member
JoBy's Avatar
It is better to have the supercharger on the drivers side. That will put it closer to the crank on the belt and reduce bearing load on all accessories after the supercharger ( alternator, waterpump ... ). I don't know if this is a big issue but anything helps. I put the alternator on the passenger side where the A/C pump used to be.
JoBy is offline   Reply With Quote
Reload this Page Attn: Brainstormers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
