Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-29-2002, 06:08 PM   #1
black bart
CF Senior Member
black bart's Avatar
Default D1-R arrived today
My new D1-R arrived today it looks awesome. :D
ATI has changed the race BOV it has a teflon seal instead of O-Ring like others use it should be more reliable. I"m going to make my dog hunt. :yesnod: :yesnod:
black bart is offline   Reply With Quote
Old 11-01-2002, 02:01 AM   #2
Light84vette
CF Senior Member
Light84vette's Avatar
Default Re: D1-R arrived today (black bart)
How much air does that blower push out? How much power do you plan on making? ALso do have any pics of the D1-R :cool:
Light84vette is offline   Reply With Quote
Old 11-01-2002, 12:44 PM   #3
92LT1Roadster
CF Senior Member
92LT1Roadster's Avatar
Send a message via AIM to 92LT1Roadster
Default Re: D1-R arrived today (Light84vette)
My friend just ordered one for his 396-L98. The box is the size of a small coffin" 5 to 6' long" it is very pretty and very expensive "polished chrome.... To answer you question it has the ability to push out 30 pounds of boost
92LT1Roadster is offline   Reply With Quote
Old 11-01-2002, 02:05 PM   #4
black bart
CF Senior Member
black bart's Avatar
The D1-R flows 2000 cfm and 32lbs.of boost. I don't have any pictures of it yet but it is polished and looks awesome. You can see specs. at http://www.procharger.com click on models for a list of all the blowers. They do not have a kit to put this blower on a vette it requires a custom install intercooler has to be fabricated to flow twice as much as the one that ATI makes for the vette also requires 3inch tubing instead of the 21/2. I mounted the blower this morning to see what mods I need to make and the one thing that stands out right away is that the hood lacks about four inches of closing. I just finished modifying the fan shroud trying to make room for the large tubes. This would not be an installation for the inexperenced to tackle. As to how much power the blower is capable of 1200hp but I don't expect to make that because of flow restrictions of the heads and intake. Heads that would flow that much would not be a good choice for a street car but I have nos and that will help make up for some of the loss. :seeya
Old 11-01-2002, 02:17 PM   #5
krivera
CF Senior Member
krivera's Avatar
Send a message via AIM to krivera
Congrats on the blower i was going to go to the D1-R but i cant get high enough in the RPM Range to utilize all the boost, like my D1 is just about right but a little bigger cam and heads would make a world of difference because i get alot of boost around 5800rpm! and the TPI takes it like a champ..WEll i guess it does not have a choice being forced in there! :D But have fun i know what the coffin looks like i was scared thinking of all the part i had to put together!
Have a good day :yesnod:
krivera is offline   Reply With Quote
Old 11-01-2002, 05:59 PM   #6
bill mcdonald
CF Senior Member
Let us know how it works out for you.
bill mcdonald is offline   Reply With Quote
Old 11-01-2002, 08:31 PM   #7
AKS Racing
CF Senior Member
AKS Racing's Avatar
I found the same thing on my '89 with the larger blower. But the aftermarket 4" lightweight (~40 lb) cowl hood helps due to the much shallower reinforcement ribs. I also mounted it different than I did on my '87 with the D-1. The tubes are all custom made from mandrel bent "U" tubes purchased through Summit. The fan shroud is gone, and the intercooler is completely custom Spearco.
Best of Luck,
Aaron
AKS Racing is offline   Reply With Quote
Old 11-01-2002, 09:05 PM   #8
Light84vette
CF Senior Member
WOW that will turn you vette into a rocket! :yesnod: What kind of transmission are you going to bolt behind that monster engine? Also are you going to swap you rear end for a stronger piece if thier is one in existence?
Old 11-03-2002, 09:08 AM   #9
jparr
CF Senior Member
CI 7-8-9-10 Veteran
St. Jude Donor '08
jparr's Avatar
hey big guy whats up!!!! rockys mad at me!! he wont start his car for me because im your freind (what a baby). It does sound mean but i told his freind you can still take him,no problem. His freind told me he will have at least 500rwhp when he gets it tuned jus for your info!! maybe ill drive out and see what your doing LOL JAY :lol:
[Modified by jparr, 6:09 AM 11/3/2002]
jparr is offline   Reply With Quote
Old 11-04-2002, 09:26 AM   #10
black bart
CF Senior Member
black bart's Avatar
Default Re: D1-R arrived today (jparr)
Well Rocky say's that he built a 302 his friends tell me it is a 408 you can't believe anything that you hear. Before I run him I was told to stay away from him that nobody could beat him but when I ran his bad nitrious mudstain I shut off after three gears because if I had stayed on the throttle any longer he would not have been in the same zip code. I don't think he will get 500 rwhp from a 302 but even if he does and we run again it will be the same results I will just have to run a little harder hell if he keeps working on that thing someday he may get it fast enough that I will have to use my nos and spray him :D I saw Rocky at the show in Wabash and I told him that I would give him a picture of my car so that he could see what the front looked like for a change. :seeya
Old 11-04-2002, 03:35 PM   #11
jparr
CF Senior Member
CI 7-8-9-10 Veteran
St. Jude Donor '08
jparr's Avatar
thats funny dick!!!!! i want to see yours when your done with it. Hey who
really know what rocky has under the hood i know he is quicker then me , but he has about $6000 more then me in it too. i think u need to put a cam in your car and when u race him tape it then post it i would love to watch that :D JAY
[Modified by jparr, 12:36 PM 11/4/2002]
Old 11-05-2002, 07:25 PM   #12
black bart
CF Senior Member
black bart's Avatar
Jay stop by sometime but you should call first or i may be gone. I have the bracket for the blower done going to Ft. Wayne to the chrome shop in the morning. I got some parts to pick up that are done and leave the blower bracket to be chromed. You know what they say if it won't run chrome it. :lol:
[Modified by black bart, 5:28 PM 11/5/2002]
Reload this Page D1-R arrived today
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
PTK TT Tuned @ A&A Corvette Performance Shinobi'sZ C5 Forced Induction/Nitrous 20 04-25-2005 01:15 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
