Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-22-2002, 07:24 PM   #1
bogo783
Junior Member
Default Ignition map
I've switched from custom chip to a fully programmable aftermarket DFI and WB. I will soon install my Vortech s-trim and H2O injection. I've been looking for information/leads how to a design a good start-up ignition map but have ended up with nothing (yet). Still stock bottom L98 (cr 10:1) so I guess not more than 8psi, camshaft is designed for peak hp's at 5500 rpm (approx. 220/230'/0.500/0.500 LSA 114'), other mods in the signature. Any information on this topic is appreciated!
bogo783 is offline   Reply With Quote
Old 10-23-2002, 03:20 AM   #2
drive it
CF Senior Member
Default Re: Ignition map (bogo783)
First off-welcome to the forum! And just curious-Goteborg? Where's that?
OK, onto your question now....The aftermarket manufacturer of your DFI should have "start up" tables for fuel, spark etc. Otherwise start with the spark table now in it-and just have to tune from there. Your dfi has knock retard? That would keep it safe. I've ended up down as low as 18deg at wot at certain loads, and just backed the idle/low load timing from 23deg to 15deg in some spots to pass smog! A lot depends on heads/porting also. Your cam specs are real close to mine-do you have to deal with smog checks where you are? Also-does your dfi use the wide band in its program to adjust wot f/a ratios? That'd be too cool!
drive it is offline   Reply With Quote
Old 10-23-2002, 01:07 PM   #3
bogo783
Junior Member
Default Re: Ignition map (drive it)
Thanks! Well they did provide me with a "safe" start-up map. This is the spark advance at WOT and load 150 (max load, +50kPa MAP):
rpm Total SA
900 12
1500 16
2000 19
2500 22
3000 25
3500 28
4000 28
4500 28
5000 29
5500 31
6000 32
The WB is only used during tuning: I put target AFR's in each cell of the fuel/air map, driving the car at a certain load and rpm during two seconds enable the computer to home in and lock on the right AFR (and yes, at WOT as well). No knock retard in the DFI but I've kept the sensor in the block and use some electronics to drive a small lamp and a buzzer. In addition I hope my EGT probe will give me some help as well.
By the way, Goteborg is the second largest city in Sweden and unfortunately we have a very seroius smog check every year.
Old 10-31-2002, 03:31 PM   #4
black bart
CF Senior Member
black bart's Avatar
Accel offers a ESC as a option for the DFI unit I don't remember what the cost was but I have one installed on my car. This will protect your engine if you have the map wrong I would suggest you get one. The kit comes with harness knock sensor everthing for the install. With only 8lb. boost you could run stock timing with intercooled procharger but I don't know if you can get away with that on your setup. Have you thought about intercooling.
black bart is offline   Reply With Quote
Old 11-01-2002, 05:45 AM   #5
bogo783
Junior Member
Default Re: Ignition map (black bart)
I will use a ESC module + knock sensor from a pre -90 corvette together with an electronic circuit to indicate detonation. I think the Accell DFI (or is it FAST?) use the same principle (using a stock ESC). I've found a really simple circuit from the SyTy board (like $5 in components) that seems to work quite well. Yes, I've considered intercooling but as indicated in my previous message I have a "slight problem" with smog control (I have to make my engine bay appear stock during inspection=removing the supercharger, brackets etc). I am however thinking about the Vortech Aftercooler, it seems quite easy to fit in the engine bay (at least compared to air/air intercoolers).
I agree with you regarding the ignition timing, I'm planning to use my stock ignition map up to vacuum, above vacuum I will try to "reverse/mirror" the stock map ( maybe a little vague but I hope you understand). Any comments?
Reload this Page Ignition map
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LT1 Ignition Control Module effects timing advance (!) Lone Ranger C4 Tech/Performance 13 06-23-2005 06:39 PM
LS1 ignition on old style small blocks Guru_4_hire C3 Tech/Performance 15 04-12-2004 12:35 PM
Is a map of ~55 at idle a vacuum leak? ANTI VENOM C4 Scan & Tune 11 01-26-2004 12:43 PM
Distributorless Ignition Monty Engine Mods 29 05-08-2003 04:17 PM
MSD Ignition Good And Bad?? 71DropTop C3 Tech/Performance 26 02-15-2003 10:14 PM
Transistor Ignition: L72 ?? hot1corvette1 C1 & C2 Corvettes 14 07-11-2002 09:55 AM
MSD 6AL Ignition Box Blake-73 C3 Tech/Performance 21 12-07-2001 12:13 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
