Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-21-2002, 12:46 AM   #1
88vetteZ52
Junior Member
88vetteZ52's Avatar
Default Another Fuel Pressure Question
I have an 88 auto coupe.
I am running 8psi of boost. 1.6 roller rockers. stock TB wtih airfoil. hooker long tube headers. Gutted cats. Holley adjustable fuel pressure regulator.
I am wondering what suggested fuel pressure I should be running. Right now, with the vac removed, it is at 47psi. It seems to do ok, but I am wondering if there is an optimal setting?
[Modified by 88vetteZ52, 3:53 AM 10/21/2002]
88vetteZ52 is offline   Reply With Quote
Old 10-21-2002, 03:55 PM   #2
SPD DMN
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
SPD DMN's Avatar
Default Re: Another Fuel Pressure Question (88vetteZ52)
There is no magical number and will vary depending on climate and altitude. 43-48 is a normal operating range though.
SPD DMN is offline   Reply With Quote
Old 11-08-2002, 04:24 AM   #3
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Default Re: Another Fuel Pressure Question (Vette92)
88 Vette,
Your pressure will determine how rich your Air fuel mixture will be at WOT... I'm running stock 24's at the moment, running 8 pounds into a intercooler.
I'm shooting right at 12.5 or right at .900 to .920 monitoring the O2's
I am right at about 75 pounds of fuel pressure WOT and 41 at idle (LT-1) ... if you can give me your approximate horsepower and what injectors your running, I can give you more specific answers...
If you are running close to 480 (where I am) your need to be close to about 36 pounds of fuel... obviously the larger the injector the less pressure but at idle too large of injectors can be tough to dial in...
Summerizing.. you sound good from idle through probably 4000 , but you need the extrra fuel pressure t keep from detonating at redline as it will lean out rapidly. I have personally seen 11 degrees of spark knock at 5600 as the air fuel was at 13.2... you should be minimum 12.5 - 12 at WOT
email me if you like...
mo
Mo_Bandy is offline   Reply With Quote
Reload this Page Another Fuel Pressure Question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
