Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-14-2002, 02:56 PM   #1
88vetteZ52
Junior Member
88vetteZ52's Avatar
Default Fuel Pump or Regulator? S/C 88
Ok, here is the background... I have a supercharged 88 vette with long tube headers, gut'd cats, flowmasters, 1.6 roller rockers and a 58 mm TB.
For about two weeks I have been popin code 33 after a few minutes of driving. I have tested/replaced the MAF, TPS, both relays, ECM and all vacuum lines. With no solution. Finally, I thought it might be the 58mm TB so I switched it back to my stock (48) TB a week ago- no code up until lastnight. When the car throws the code 33 it goes into limp mode and I can turn the car off for a couple minutes and the code goes away for awhile. It doesn't happen everytime I start the car or every time I drive the car. I have a sudden loss of power right before the code is thrown & it surges right around 1600rpm afterwards. I don't get the code as frequently with the stock TB as with the 58mm TB.
I am wondering if possibly I am not getting enough fuel for the amount of air? The timing was adjusted with the 58mm TB. I think the car is running lean now. I want to put a larger TB on (is the 58 too much?), but I need to find out what the problem is first with this code 33. If I do need more fuel - should I get a high pressure pump? or an adjustable fuel regulator? (adjust the timing of course) And if I do this could I put an 8lb pully on the car w/o doing any damage (no intercooler)?
Thanks! :cool:
[Modified by 88vetteZ52, 6:15 PM 10/14/2002]
88vetteZ52 is offline   Reply With Quote
Old 10-15-2002, 02:15 AM   #2
drive it
CF Senior Member
Default Re: Fuel Pump or Regulator? S/C 88 (88vetteZ52)
Have you had a custom chip burned for it!? Your car could really use it now. There is a table under constants to adjust the parameter for code 33 setting. With mods you have to increase it.
Also have you had a chance to wide band it? Check the f/a at wot? You'll probably find it way lean under boost-in addition to tuning with the prom I had to install an fmu and a walbro 340 fuel pump. Just don't want to see you burn a piston!
And no a 58mm isn't too big. Please don't increase your boost till you can dyno/tune it with a wideband......
drive it is offline   Reply With Quote
Reload this Page Fuel Pump or Regulator? S/C 88
Tags
88vettefuelpumpregulator, 88vettefuelregulator
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
BBC performer Engines, give us your combos! Lasse C3 Tech/Performance 11 05-17-2002 11:36 PM
Might Have Found A Set Of Heads bence13_33 C3 Tech/Performance 12 12-05-2001 11:26 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
