Interested in installing a N2O kit on my 1993 LT-1,(speed density system). I have looked at the NOS, TNT, Zex and the Compucar, what are ya'll opinions regarding these systems, aside from geting a good Walbro fuel pump, what other mods should I make to keep it alive, I have a stage 2 JET chip now, should I get rid of it, or get a retard box? digital MSD? will that work with the optispark? , what are ya'll running
Re: wanna nossss (tee hee) the LT-1 (phartknocker)
Check out what your chip is doing to the timing. I had a NOS dry kit and replaced it with the TNT wet throttle plate. If you do this you need 90 degree lines to clear the hood from the throttle body. MSD digital 6 retard, window switch, wot switch, bottle heater.
I took my chip out. Good luck - I have not had any for some time :seeya
Fuel pressure safety switch. It will kill your nitrous system if your feul pressure drops to an unsafe level. It would be a bad thing to inject nitrous with out enough fuel. :yesnod:
