I have a 94 6 speed LT1 Coupe with a touch over 100k miles that I recently installed a rear mounted 76mm On3 Performance Turbo, NGK TR6 plugs with .035" gap, Holley H-50 50 lbs injectors, and Walbro 255L/Hr high-performance fuel pump. Now the only thing I am missing is a good tune to get this car up and running. The motor is still bone stock, and I am only looking to make 5-9 lbs of boost max on a safe tune. Is there any places around Central Massachusetts where I can go to get this car dyno tuned?
Why not learn to tune it yourself with some help from me ? greg
I was tossing around the idea.... how much does it cost for the software and how easy is it... how could you help would you provide me a base tune that I just need to tweak a little bit
