Strongest manual gearbox?
Hi.. Ok the 4+3 finally gave up on me yesterday. For 375 miles it stood up for the turbo abuse but last night i made a 2nd through 3rd pull and it started rattling really bad then Bang!! So i rolled to a stop trying to at least having it moving to get home, but the first 3 gears are gone and reverse and 4th gear sounds like a rockcrusher. So i had it towed .. Anyway, do you have any idea of what gearbox to go with? I like to keep the stick so manual it is! What about the Tko 600? A 5-speed would have been great.
/Svante
/Svante
You can find a used ZF6 out of a 90's Vette and it should be pretty close to a bolt in. Those hold up very well. Sometime during '93 the switched from a black tag to a blue tag. The blue tags didn't hold up as well, but had less noise or something like that.
On a side note I have a McCloud clutch/flywheel setup for the ZF6 to a SBC setup. I had to get it special since my LT1 had a rear main conversion. Its used but in good shape if you are interested.
I removed the gearbox yesterday and it have cracked the housing between the counter and mainshaft and the gears are stripped
Thanks a lot for the reply.
/Svante.
/Svante
I have a black tag ZF I have been abusing at the drag strip for years with nitrous, slicks and 4000+ rpm clutch dumps and never broke the trans. I have broke about everything behind the trans (before the Ford 9") but not the trans.
How much torque are you putting out on your motor?
Thanks.
Try looking at the TKO 5-speed here This transmission is a bolt-in replacement for the 4+3. It's pricey but it does come with everything you need for the install. It's supposed to be good for up to 600 ft-lbs of torque for the TKO600 box. The 500 and 600 versions have slightly different gear ratios.
A ZF trans would work but you would have to find the components to install it into an early C4. Others have done this swap so use the Search function to find information about how it was done.
I think the ZF would be an easy retrofit (I run a ZF 6 speed behind a 383 w/16 psi boost). Try this guy for blueprinted trans for your power level:
http://www.zfdoc.com/index.htm
I just had the zfdoc blueprint the tranny in my zr1 and I have never had a tranny that shifts as smooth and positive in my life. after looking at the guts of this transmission with bills mods it could handle the 1000 hp easy . it is an amazing piece.
