Oil cap adapter
Old 07-23-2014, 09:45 PM
Impala Balko
Impala Balko's Avatar
Default Oil cap adapter
So i finished my remote turbo build however I have a bad oil leak right where my oil return goes through my oil cap. Is it possible to purchase a oil cap or a set of valve covers that has a -10an flared male adapter built into it?
Old 07-23-2014, 09:53 PM
Impala Balko
This is the closest thing I found which according to the picture it looks like it could fit. Has any one tried this part on a 94 corvette LT1
http://www.hawksthirdgenparts.com/pr...N-Fitting.html
Old 07-24-2014, 06:47 AM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
As long as your covers use the "notched" oil fill cap then yes it's a fit. Your cap now needs to look exactly like the image in the link.
Earlier LT covers and some aftermarket covers use a nearly "fully threaded" cover. I believe all '92 covers were like these.
Old 07-25-2014, 06:15 AM
Impala Balko
So i ordered that part it appears that it should fit even though it's for LS motors
Old 07-25-2014, 08:59 AM
WVZR-1
WVZR-1's Avatar
There is no difference in the LT/LS oil cap retention. The vendor is likely an LS orientated reseller and that's his only concern.
You will be fine!
Old 07-25-2014, 02:36 PM
Impala Balko
You will be fine!
I really wish I knew about this before I drilled the first oil cap and had it leak all over the place. ...ohh well
To Oil cap adapter
Quick Reply: Oil cap adapter
