Remote mount Turbo Oil supply?
Old 06-17-2014, 10:16 PM
Impala Balko
Impala Balko's Avatar
Default Remote mount Turbo Oil supply?
I am in the process of installing my remote mount turbo setup on my 94 Corvette and i can not figure out where I am supposed to plumb my oil lines to get pressurized oil. Mine has an oil temp sensor screwed in the same exact location that I thought I was supposed to run my line. There is a square socket bolt right above the filter. Is that where i should be tapping into or should I be looking at the bolt above the sensor? What did you guys do for your supercharger or turbo LT1 builds to supply oil. Please show me pictures and explain how you did it.
It's confusing because this is the diagram I got from searching around showed right where I have a oil temp sensor pluged in
Old 06-18-2014, 11:09 PM
smooth1990
smooth1990's Avatar
Mine goes above the filter on my 1992. No pics off hand. Sorry.
Old 06-19-2014, 06:38 AM
Impala Balko
So right where the square drive bolt is on my pictures.
Old 06-19-2014, 09:10 AM
smooth1990
smooth1990's Avatar
Check your thread in tech. I posted pictures
Old 06-19-2014, 07:09 PM
smooth1990
smooth1990's Avatar
Here is a pic of mine.
Old 06-29-2014, 04:46 PM
Impala Balko
I have my T fitting in now all I need to do is wire my scavenge pump, plumb my oil return into the valve cover, wire some gauges, finish my cold side and she is ready to tune.
To Remote mount Turbo Oil supply?
Quick Reply: Remote mount Turbo Oil supply?
