Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2002, 02:52 PM   #1
antroc
Junior Member
Default are bigger injectors needed
are bigger injectors needed with what i am running list is 350 .30 over trickflow heads hooker headers slp catback system 24pound injectors 3200stall converter comp cam 220/230 dur 510/510 lift 114 lop sep paxton supercharger 9.5pounds of boost stock rearend gears 3.23 also its a 1988 camaro iroc if that will help because get better help from you guys at this forum :rolleyes:
antroc is offline   Reply With Quote
Old 07-18-2002, 03:32 PM   #2
8388
CF Senior Member
8388's Avatar
Default Re: are bigger injectors needed (antroc)
[quote]are bigger injectors needed with what i am running list is 350 .30 over trickflow heads hooker headers slp catback system 24pound injectors 3200stall converter comp cam 220/230 dur 510/510 lift 114 lop sep paxton supercharger 9.5pounds of boost stock rearend gears 3.23 also its a 1988 camaro iroc if that will help because get better help from you guys at this forum :rolleyes:
You can make 24 lb work if necessary, but you'll have to increase the pressure under boost using an FMU, and may end up pushing the injectors beyond the 80% cycle, which will shorten their life.
You would probably better off with 30 lb injectors. To know for sure, it would be best to put the car on a chasis dyno with an airflow ratio sensor and see where your at to start with, and go from there.
The right way would be to have the chip mapped for fuel and timming with the proper size injectors, and not have to depend on an FMU, but to do so you'll need to be running a 2 or 3 bar map sensor in order to sense boost. What are you running right now a MAF or MAP sensor ?
8388 is offline   Reply With Quote
Old 07-18-2002, 03:48 PM   #3
antroc
Junior Member
Default Re: are bigger injectors needed (8388)
i have a maf system
Old 07-18-2002, 05:36 PM   #4
krivera
CF Senior Member
krivera's Avatar
Send a message via AIM to krivera
i have 24# seem to work fine?
krivera is offline   Reply With Quote
Old 07-20-2002, 11:38 PM   #5
quiksilver458
CF Senior Member
quiksilver458's Avatar
Send a message via AIM to quiksilver458
24 pound should do the trick if tuned right.. i personally would try to sell those off an get some 30 pound ones.. seem to work great on buddies 94 z28..
quiksilver458 is offline   Reply With Quote
Old 07-21-2002, 03:50 AM   #6
antroc
Junior Member
Default Re: are bigger injectors needed (quiksilver458)
thanks quiksiler458 for information i seen 30pound injectors on ebay for 100 bucks
Reload this Page are bigger injectors needed
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
30# injecters were too BIG for my 383. Are 22# too small? B84RADR C4 Tech/Performance 111 02-21-2004 05:13 PM
Why go to Higher #/hr Fuel Injectors? Da Wiz C4 Tech/Performance 28 08-18-2003 03:27 PM
What Kind of Injectors Should I Get...? MiamiDave C5 Tech 14 07-18-2003 01:33 PM
BB PRT's are the SHIZNAT! C5Noir C5 Tech 68 03-22-2002 01:40 AM
Engine opinions needed! 85z51vette C4 Tech/Performance 17 10-27-2001 03:16 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
