Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-17-2002, 02:44 PM   #1
Tomas
CF Senior Member
Tomas's Avatar
Default Going for Nitrous, need a little help please
Hello everyone
Now im going for nitrous. For the moment a have Supercharged L98 with superram. Im looking for 75-150HP. I have thinking to go for NOS. Is there any kit that I can go for directly? Partno? Or do I have to order everything separate? I must also have partnumbers for every neccesary accessories like, fuel pressure safety switch, purge valve + some other things that you recommend me
I have a Walbro 340 pump. Will that pump handle 500+150 HP??
If not What extra pump are you recommend me?
I have Accel 30lbs injectors, Do i need to put bigger first? If so size?make?
Anyone pics over Supercharged, superram L98 with nitrous?
I hope I get lots of replys,
regards
Tomas :D :D :D :D :D :D
Tomas is offline   Reply With Quote
Old 07-17-2002, 03:09 PM   #2
SPD DMN
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
SPD DMN's Avatar
Default Re: Going for Nitrous, need a little help please (Tomas)
Good luck with adding that much Nitrous to an already supercharged L98. Is the motor a built motor or stock bottom end.
SPD DMN is offline   Reply With Quote
Old 07-17-2002, 03:27 PM   #3
Tomas
CF Senior Member
Tomas's Avatar
Default Re: Going for Nitrous, need a little help please (Vette92)
Hello Vette92
Yes it is a built motor with almost the best parts money can buy.
Old 07-18-2002, 04:42 PM   #4
Finland
CF Senior Member
Finland's Avatar
:eek: :smash: :eek: :smash:
Finland is offline   Reply With Quote
Old 07-18-2002, 05:10 PM   #5
krivera
CF Senior Member
krivera's Avatar
Send a message via AIM to krivera
DAMN IT! i wish i had a digital CAM! i would show you my setup on my vette! i am running a 150shot with 10psi...To be honest i never need the Juice but i have ran into me being dumb and drunk and having fun on the bottle :reddevil But my bottom end is stock, actually my whole motor and injection is stock except the injectors i have 24# (stock 22) So my L98 has 100K on the block and she is standing like a champ! So i dont know as for fuel, etc...? I do have a MSD 6a, MSD wires and coil? but other then that it is stock engine? Trust me you will have fun and the kit i have is a 5151 from NOS it sits right after the throttle body and it works well with my speed density system on my car. Thanks i hope this helps! :D
krivera is offline   Reply With Quote
Old 07-18-2002, 05:13 PM   #6
SPD DMN
CF Senior Member
Cruise-In I Veteran
SPD DMN's Avatar
Default Re: Going for Nitrous, need a little help please (krivera)
You can get away with a lot more at that elevation too. I know one motor was supposed to go up to Denver from LG's and I want to say it was a 11.5:1 396 running 14psi of boost (in a Camaro). He said he would not even run that thing on the dyno here in Dallas.
Old 07-18-2002, 05:33 PM   #7
krivera
CF Senior Member
krivera's Avatar
Yes Very true! 5280 above Sea Level makes a huge difference and even on some day's with some tools at the track i have seen the air be so thin when you would run your car it was like 8000 feet above...So that is true...as for in dallas i had a friend that had TA with 150shot and 8psi and it was tuned to the tea and he had the best engine work money could buy and his car lasted 50K and that is running it hard? I am no machnic but i know his car was fast and i should call (cliff) and has him if he still has the car! :confused:
Old 07-19-2002, 04:12 AM   #8
Tomas
CF Senior Member
Tomas's Avatar
Hello Krivera
I was looking in summit racing for the NOS 05151 kit and found it, but is the plate between the superram and the Throttle body for 52 or 58mm throttle body? I need 58mm plate. And try to borrow a digital cam from some friend so i can see your setup. Thanks
regards
tomas
[Modified by Tomas, 1:13 AM 7/19/2002]
Reload this Page Going for Nitrous, need a little help please
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
[BG Speed Demon] issues at idle LiveandLetDrive C3 Tech/Performance 81 04-28-2005 10:35 AM
What's involved in setting an LT5 up for an auto? compuvette C4 ZR-1 Discussion 24 05-26-2004 01:40 AM
427 is up an running!!!!!! (VERY LONG) LOOKN2GETSTROKED C5 Tech 24 11-10-2003 12:42 PM
NEED HELP - 422/427 STROKER (TUNERS/VENDORS) LOOKN2GETSTROKED C5 Tech 20 06-08-2003 10:37 PM
To [Race City Gang], [QCCC] and all Charlotte area c5 owners!!!! OvrEagR Southeast 54 05-13-2003 09:26 PM
I need some NITROUS help please...! Jimmy Smits C5 Forced Induction/Nitrous 18 05-08-2003 11:47 PM
Newbie needs a little help please Wongsifu C3 Tech/Performance 10 09-11-2001 11:20 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
