C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
07-17-2002, 10:11 AM
CF Senior Member
Clicking sound when nitrous is activated
yesterday I noticed that when the window switch kicks in a 3,000 rpm I hear this rapid clicking noise. I never noticed it before.
I would assume the window switch might click once when its acitvated and another time when is shuts down, but the clicking noise doesnt sound right.
Jim
07-17-2002, 10:26 AM
CF Senior Member
Re: Clicking sound when nitrous is activated (Hammer)
Sounds like you may have a loose connection or something. You really should only hear one click when the solenoid opens.
07-17-2002, 01:25 PM
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
Re: Clicking sound when nitrous is activated (Hi-psi)
Agreed.
Also something to check is your fuel pressure safety switch (if so equipped). It may be cycling the system on and off if it is set too close to the normal pressure. If the switch is installed right next to the selenoid, it may be sensing a pressure drop upon selenoid activation.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
