Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-16-2002, 06:01 PM   #1
drive it
CF Senior Member
Default Any SC for an 86 that's still "smog legal"?
I looking at putting a sc on my 86 (can never have too much hp!).
But....it looks like they all eliminate the smog pump!
Am I wrong on that? I'd probably convert to sd or even a sy ty ecm with 2 bar map to run it; and keep emissions clean out the tailpipe. But for visual it's gotta have a smog pump, and I wouldn't want to tear it apart every two years....
Thanks for any info!
drive it is offline   Reply With Quote
Old 07-16-2002, 07:09 PM   #2
gcrouse
CF Senior Member
gcrouse's Avatar
Default Re: Any SC for an 86 that's still "smog legal"? (drive it)
The ATI kit has an air fitting after the SC which connects to the original smog pump hose; it siphons off a small amount of boost which blows into the exhaust manifolds / catalytic convertor. Works just like the original smog pump. I believe the system is certified 50-state legal.
gcrouse is offline   Reply With Quote
Old 07-16-2002, 07:58 PM   #3
krivera
CF Senior Member
krivera's Avatar
Send a message via AIM to krivera
Default Re: Any SC for an 86 that's still "smog legal"? (gcrouse)
no smog pump here :D
ATI D-1
krivera is offline   Reply With Quote
Old 07-16-2002, 10:39 PM   #4
bill mcdonald
CF Senior Member
I am not possitive about the old paxton kit, but the ATI is not smog legal in ca on the L-98's for the visual.
the vortech kit put together by carroll is not legal in ca either.
bill mcdonald is offline   Reply With Quote
Old 07-17-2002, 04:28 PM   #5
drive it
CF Senior Member
Default Re: Any SC for an 86 that's still "smog legal"? (bill mcdonald)
I'm not real concerned with the sc not having eo #'s for visual(I can squeek by there!)-just that I can still retain the smog pump to satisfy the "spirit" of the smog check.......
gcrouse-so you do have that setup on yours???? And it works for the air injection? Hmmmm, what about during non-boost operation?
Old 07-18-2002, 02:37 AM   #6
gcrouse
CF Senior Member
gcrouse's Avatar
Well the SC is always blowing air so it's fine as an AIR injection source. Only when SC airflow output exceeds the engine's NA volumetric efficiency does it actually make boost; but it's still blowing air even at low rpm.
Actually I never hooked up my AIR injection and never had any emissions trouble. A well programmed computer using O2 sensor feedback plus MSD (or similar) ignition should not have unburned HC exiting the cylinders anyway. Except possibly when you're foot's to the floor under full boost with a slightly rich mixture to avoid detonation- but they don't test for that.
The other thing the AIR injection does is warm up the catalytic converters so they start working sooner after starting from cold; so just make sure you've driven a while so those things are hot when you go for the test.
A pair of hi-flow cats is the only emissions stuff I have, and it passes the IM240 dyno test (which is supposedly similar to CA) real clean. Biggest factors are a reasonable cam and proper ECM tuning.
Reload this Page Any SC for an 86 that's still "smog legal"?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
