Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-15-2002, 07:47 PM   #1
mn_vette
CF Senior Member
mn_vette's Avatar
Default Should I try a 150 hp Shot?
I've got a 255lph fuel pump and I'm running the stock FPR which runs rich. But I don't have a MSD 6A. Do you think I would be ok running a 150hp shot? NX says I'm ok, my mechanic says I'm ok, I'm thinking of doing a rebuild this winter anyways, but I'd like to have the option of not incase my budget gets tight. What's your opinion.
mn_vette is offline   Reply With Quote
Old 07-16-2002, 12:35 PM   #2
RatRacer
CF Senior Member
RatRacer's Avatar
Default Re: Should I try a 150 hp Shot? (mn_vette)
150 will be the limit on the stock cast pistons. You'll need to retard the timing two degrees, close the plug gaps to .035" and run good gas. As long as you do that and your a/f ratios are around 11:1 you'll be fine.
RatRacer is offline   Reply With Quote
Old 07-16-2002, 12:53 PM   #3
krivera
CF Senior Member
krivera's Avatar
Send a message via AIM to krivera
yes 150 shot!
krivera is offline   Reply With Quote
Old 07-16-2002, 01:06 PM   #4
mn_vette
CF Senior Member
mn_vette's Avatar
Default Re: Should I try a 150 hp Shot? (RatRacer)
The plug gaps are already closed. And I always run 92 octaine or higher when I can get it. What would you guys suggest to retard the timing? I was thinking the MSD 6A or is there something else that might work better?
Old 07-16-2002, 02:34 PM   #5
YellowFvr
CF Senior Member
msd digital 6 (6A or 6AL doesn't have retard) or jacobs nitrous mastermind (comes with a nice progressive controller)
[Modified by YellowFvr, 5:34 PM 7/16/2002]
YellowFvr is offline   Reply With Quote
Old 07-20-2002, 11:41 PM   #6
quiksilver458
CF Senior Member
quiksilver458's Avatar
Send a message via AIM to quiksilver458
150 all the way!! :blueangel:
quiksilver458 is offline   Reply With Quote
Old 07-21-2002, 01:13 PM   #7
honas
CF Senior Member
honas's Avatar
I spray 150. I'm not sure I understand the worry about timing with the pcm we have. Mine takes timing out when it hears knock. It has taken 11 degrees out before. Let the computer do the work. It's way smarter than any msd.
honas is offline   Reply With Quote
Old 07-21-2002, 03:28 PM   #8
RatRacer
CF Senior Member
RatRacer's Avatar
Default Re: Should I try a 150 hp Shot? (honas)
The concern about taking timing out is that with stock cast pistons, by the time the ECM receives the signal from the knock sensors you are already doing damage to your engine. If the detonation is bad enough it will lead to preignition which will then melt down your engine. This happens very quickly and the larger the nitrous shot the quicker it happens. If you are relying on the ecm to take timing out when you detonate on nitrous you are playing with fire.
You've been warned.
Old 07-23-2002, 10:58 AM   #9
Hammer
CF Senior Member
Support Corvetteforum!
Hammer's Avatar
I just went back to a 150 shot from a 100 shot. I have all the safety precautions available, but it still feels a little too strong, I will be spraying less often with the 150 than the 100.
Jim
Hammer is offline   Reply With Quote
Old 07-23-2002, 12:35 PM   #10
69 N.O.X. RATT
CF Senior Member
69 N.O.X. RATT's Avatar
Location: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Should I try a 150 hp Shot? (Hammer)
I have an adjustable timing control (MSD part# 8680) plugged into my 6al. It allows you run run full timing and when you want to run the shot you dail out the timing you want (up to 15 degrees) The knob is mounted by my NOS activation switch. For running a single stage of NOS it is very convenient.
69 N.O.X. RATT is offline   Reply With Quote
Old 07-23-2002, 07:26 PM   #11
95AquaC4
CF Senior Member
95AquaC4's Avatar
Quote:
The concern about taking timing out is that with stock cast pistons, by the time the ECM receives the signal from the knock sensors you are already doing damage to your engine. If the detonation is bad enough it will lead to preignition which will then melt down your engine. This happens very quickly and the larger the nitrous shot the quicker it happens. If you are relying on the ecm to take timing out when you detonate on nitrous you are playing with fire. You've been warned.
:yesnod: :yesnod: Amen to that. I am spraying 150 with 5 degrees retard through my Digital6.
[Modified by 95AquaC4, 5:26 PM 7/23/2002]
95AquaC4 is offline   Reply With Quote
Old 08-19-2002, 09:54 AM   #12
mn_vette
CF Senior Member
mn_vette's Avatar
Well, I tried it. and my engine is still going just fine. I didn't change anything with the timing but I did have to adjust my fuel pressure saftey cutoff switch for the Nitrous system. I didn't really set it when I installed the system since I didn't have a fuel pressure meter but I called NX and that's what they told me to do and it seems to be just fine now.
Old 08-21-2002, 01:22 PM   #13
Finland
CF Senior Member
Finland's Avatar
My experience says: Be carefull with the 150 shot...
Check this one out http://forums.corvetteforum.com/zerothread?id=356911
[Modified by Finland, 6:22 PM 8/21/2002]
Finland is offline   Reply With Quote
Old 08-21-2002, 02:06 PM   #14
SPD DMN
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
SPD DMN's Avatar
Default Re: Should I try a 150 hp Shot? (Finland)
I blew out a ring on a 150 shot in stock form. I always recommend no more than a 100 shot on a stock motor.
SPD DMN is offline   Reply With Quote
Old 08-23-2002, 02:31 AM   #15
Superj
CF Senior Member
Superj's Avatar
Send a message via ICQ to Superj
Default Re: Should I try a 150 hp Shot? (Vette92)
I'd agree.
<----currently using 100 shot.
Superj is offline   Reply With Quote
Reload this Page Should I try a 150 hp Shot?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Would you cheat to win a Trophy? N20 in a N/A class?? 427Hotrod C5 Tech 64 02-03-2005 02:36 PM
Would you Cheat to win a Trophy??? N20 in a N/A Class?? 427Hotrod C3 Tech/Performance 40 02-03-2005 12:32 PM
ZR-1 vs 1000 HP Supra = Blown Motor LIMEY C4 ZR-1 Discussion 57 04-13-2003 06:54 PM
Davidmax, did your 427 TT get beat by a Supra? flynbludream C5 Forced Induction/Nitrous 74 07-18-2002 01:19 PM
Got a Maranello, ZO7 must go... SW C5 Corvettes for Sale 109 06-11-2002 08:58 PM
A real race.. 90 ZR1 VS 02 405 HP Zo6 Ultra Slow C4 ZR-1 Discussion 63 02-21-2002 09:25 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
