Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-11-2002, 07:00 PM   #1
vvv90
CF Senior Member
vvv90's Avatar
Default What kind of numbers should I expect ?????
....with a standard ATI intercooled kit running at 6 psi, w/ 30 lb injectors. Everything else being stock
HP = ????
ET times = ????
Check sig for other stuff.
vvv90 is offline   Reply With Quote
Old 07-15-2002, 05:47 AM   #2
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Default Re: What kind of numbers should I expect ????? (vvv90)
vvv90,
I would guess in the neighborhood of about 420 HP, which would probalby put you in the mid 12's. The main problem Ihave is getting the power to the ground... Irun consistant 4.7 0-60's but I'm smoking tires through 2nd gear. My car with an LT1 the back end is like 1560 lbs. I've been hampered by the knock retards approching 3-5 degrees, I have opted to install the ATI intercooler.
My setup is similar to your except I'm running about 8 pounds. I'm thinking i'm around 430 horse possibly on the conservative side... I am installing the intercooler as we speak so it will be interesting to see what a difference it makes.. possible 475... with full advance and no knock retard.
Hope this helps... you may want to invest in a logging program it is VERY helpful in giving you an idea of where your at with out having to dyno right away...
Mo
Mo_Bandy is offline   Reply With Quote
Old 07-19-2002, 05:16 PM   #3
vvv90
CF Senior Member
vvv90's Avatar
Default Re: What kind of numbers should I expect ????? (Mo_Bandy)
Thanks! But only mid 12's ??? I would think low 12's. Afterall, the Z06 runs mid 12's with 20 less HP, and the new PIG-of-a-car SVT Cobra w/ 390 will run mid to high 12's.
How much would a set of drag radials--315's out back help?
Old 07-19-2002, 06:13 PM   #4
SPD DMN
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
SPD DMN's Avatar
Traction is everything when it comes to making good times. You can have 800 horsepower, but if you don't have traction you can run 14's.
SPD DMN is offline   Reply With Quote
Old 07-19-2002, 09:49 PM   #5
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Default Re: What kind of numbers should I expect ????? (Vette92)
vvv90vvv
I agree you could probably hit low twelves... hope so in fact! I was being conservative as we are dealing hypotheticals not knowing exactly what HP you are making.
I was passing on my experience , which Vette 92 also added... Based on your setup being similar to mine, I have major traction issues, and I'm assuming you will face the same situation perhaps even more so than I since you are running even more boost.
Drag radials, 315's are about 200 a piece for a set of Kumo's. I've looked into that as well... I'd be interested in knowing how much difference they make please let me know
Once you get some numbers I'd love to see them good luck on your project!
Mo
[Modified by Mo_Bandy, 6:53 PM 7/19/2002]
Old 07-20-2002, 11:35 PM   #6
quiksilver458
CF Senior Member
quiksilver458's Avatar
Send a message via AIM to quiksilver458
with good driving , and 315's in back, very high 11's is not out of reach.. i've seen some local guys at the track 3.07 gears, an roughly 420 rwhp hitting 12 flats... :jester
quiksilver458 is offline   Reply With Quote
Old 07-22-2002, 01:40 PM   #7
vvv90
CF Senior Member
vvv90's Avatar
Default Re: What kind of numbers should I expect ????? (quiksilver458)
High 11's, that would be incredible. Here's what I'll do. Since I just got my Kd's recently and I'm pretty sure my wheels are 9.5's I'll install the s/c, go to the track and then get some 315's and run the track again. I'll be posting my time differences with the drags.
Thanks for the info. guys. I know traction is important, I was just looking for personal experience differences w/ numbers. I'll make some myself I guess. :cheers: :cheers: :cheers: :cheers:
Reload this Page What kind of numbers should I expect ?????
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Just ordered ATI Procharger for my ARE Stage II w/ 110LSA - Should I get the 5# or 7# pulley? Stunt C5 Tech 19 02-01-2002 12:26 PM
Should I get my L98 heads ported? C4-Wolf C4 Tech/Performance 9 01-10-2002 09:44 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
