Latest AEM Meth Injection Kits! Good Price!
Supporting Vendor
AEM’s Boost Dependent PN30-3300 Water/Methanol Injection kit
Water/methanol injection for gas engines is a proven means for effectively reducing engine inlet air temperatures
and suppressing harmful detonation on forced induction and high performance naturally aspirated race engines.
This allows racers to reliably increase boost and advance ignition timing—without using high-octane racing fuel—for power gains of up to 20%.
For more in depth info and specs click link. http://www.saccitycorvette.com/AEMMethInjectionkits.html
only $429.95
AEM’s Naturally Aspirated (N/A) PN30-3350 Water/Methanol Injection.
Good for 5-10% HP increase on N/A engines.
http://www.saccitycorvette.com/AEMMethInjectionkitsNA.html
only $429.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
A Meth kit will also clean the carbon off the intake valves and pistons.
Supporting Vendor
We have them for N/A cars! 5-10% hp gains on Naturally Aspirated cars!
Supporting Vendor
Supporting Vendor
Did you know: The name "Corvette" was borrowed from a line of small, fast navy ships used in World War II.
Supporting Vendor
The first generation Corvette was introduced late in the 1953 model year. Originally designed as a show car for the 1953 Motorama display at the New York Auto Show, it generated enough interest to induce GM to make a production version to sell to the public. First production was on June 30, 1953.
Supporting Vendor
The second generation (C2) Corvette, which introduced Sting Ray to the model, continued with fiberglass body panels, and overall, was smaller than the first generation. The C2 was later referred to as mid-years.[19] The car was designed by Larry Shinoda with major inspiration from a previous concept design called the "Q Corvette," which was created by Peter Brock and Chuck Pohlmann under the styling direction of Bill Mitchell.
Supporting Vendor
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9 Timing and Rear Main cover and seals.
The AlignIt tool gets the timing & rear main covers centered perfectly with the crank and installs the seal in seconds! Check out the videos.
Having the seal centered accurately with the crank minimizes the chance of seal leakage.
Timing Cover AlignIt Only $26.95
Rear Main AlignIt Only $37.95
Hub simulator only $23.95
Buy more than one of the AlignIt Tools and save!
Supporting Vendor
AEM’s Water/Methanol Injection Filter can filter particulates as small as 40 microns. It protects the working parts of the water/methanol system and the engine from particulates in the water/methanol mixture when installed in-line before the water/methanol pump, and can be used on virtually any water/methanol injection system using ¼” OD tubing.
Supporting Vendor
Both the power and ground wires for the pump are included in the harness which simplifies the wiring process and eliminates any chance of the pump accidentally activating from a short in the system.
Supporting Vendor
AEM’s engineers spent extensive time developing the controller’s flow control strategy for a more linear flow output delivery.
Supporting Vendor
We have Fangs, Alignit Tools,Big 3, Coolits,Optisparks Please check our Website http://www.saccitycorvette.com/index.html
