This seems to work ok, just need to relocate the battery.
Sorry about the crappy picture.
The best supplier of the tubing is:
http://www.racerpartswholesale.com/duct.htm
I tried to put this in as a tech tip but got lost.
Procedure to Relocate Air Filter and Battery for ATI Supercharger
Parts Needed:
Optima Red Top 75/35
http://www.optimabatteries.com/products/pdf/7535.pdf
Available off the shelf at Pep Boys for $107
Vinyl Coated Steel Battery Tray $3 - Pep Boys
Battery Hold Downs $3 - Pep Boys
Vinyl Coated Steel Battery Top Hold Down $4 - Pep Boys
Battery Terminal Corrosion Protection $1 - Pep Boys
Battery Terminal Covers - Black and Red $2 - Pep Boys
Stinger 150 Amp Electronic Circuit Breaker Part Number SCB150
http://www.stingerelectronics.com/st...se_holders.htm
(6) Stinger $10 Each
(2) Stinger Top Mount Battery Terminals $10 Each
http://www.stingerelectronics.com/st..._terminals.htm
12 Feet of 4 Gauge Monster Cable (Red) $3/Foot
3 Feet of 4 Gauge Monster Cable (Black) $3/Foot
12 feet of flexible black automotive wire protector
Insulated Battery Terminal Post Item: 228601---POWER POST 3/8 Price: $8.99 BoatUS
Misc. -
8" x 1" Thin Aluminum (Available at Lowes)
Misc. Bolts
Tie Wraps
Air Ducting -
4" Silicone High Temperature Duct Hose
Part # THESS-400 4" $82.99 Racer Parts Wholesale.com
Breathless Performance
Part Number 100-210(3) C5 Air Filter Red 69.99
(2) 4" SS Screw Clamps
Procedure:
On the passenger side rear storage compartment, remove the storage tray and the cloth storage compartment lining.
Remove the 8 Phillips screws supporting the storage compartment lid assembly and remove the lid assembly.
Measure and drill holes in aluminum bar to match holes in battery storage tray and mark and drill holes in bottom of storage compartment. Place battery tray in compartment, using bolts, and washer and secure aluminum bar on underside of compartment with nuts and washers. Mount battery with posts towards the drive shaft rather then towards outside side. Install terminal corrosion protection.
Drill two holes for battery cables in side of storage compartment for battery cable egress.
Measure, mark and drill to holes in side of storage compartment for circuit breaker.
Mount battery in tray.
Mount circuit breaker on side of storage compartment and secure with bolts.
Put black automotive wire protector over positive leads. Run positive lead thru storage compartment access hold, over c-beam (thingy the drive shaft is surrounded by and over to driver's side in front of rear wheels. Secure with tie wraps to existing wiring harness that runs over the c-beam.
Remove front battery access panel, remove front battery.
Use an electric wire fish tape to fish positive electrical lead through rocker panels on driver side and into engine battery compartment.
Run ground wire from negative top battery post, thru access hole, and ground to frame.
Do not remove original battery tray. Remove the back most bolt from the battery tray and use this bolt to support the new positive insulated battery post. Connect original battery post to new battery lead on the insulated post. Cover with provided insulating cover.
Tie wrap everything neatly.
Air Duct Installation:
Remove existing air filter from ATI unit.
For ease in installation, remove wiring harness from cruise control and two vacuum lines from cruse control to ease installation. Disconnect wiring harness for cable that runs along rear inside of forward wheel well.
Fish new flexible air duct under cruse control support beam, under master cylinder, and up and around into ATI air intake. Secure with screw clamp. Cut air duct to length. Install air filter to end of duct and secure with screw clamp. Place on battery tray.
Reinstall battery access panel. Reconnect all vacuum lines, and electrical harnesses.
The 4" silicone works perfectly with some snaking.
