Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-08-2002, 09:55 PM   #1
dizwiz24
CF Senior Member
Default If I rplc stk fuel pump with a Walbro pump will I need the aux inline pump?
title says all, I am thinking about adding nitrous. If I do, would it be easier to just replace the stock fuel pump with the Walbro fuel pump instead of fooling around with splicing an auxiliary inline fuel pump in the line?
dizwiz24 is offline   Reply With Quote
Old 07-09-2002, 06:04 PM   #2
SPD DMN
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
SPD DMN's Avatar
Default Re: If I rplc stk fuel pump with a Walbro pump will I need the aux inline pump? (dizwiz24)
Yep. I know a guy that ran a 396 with 24# injectors and a 150 wet shot using only a 255lph in tank replacement pump. I would think it would feed it well enough. Even the stock pump will feed 100 shot on a stock motor just fine.
SPD DMN is offline   Reply With Quote
Old 07-16-2002, 03:33 PM   #3
gcrouse
CF Senior Member
gcrouse's Avatar
Nope- the Walbro will do just fine all by itself.
gcrouse is offline   Reply With Quote
Old 07-28-2002, 06:03 AM   #4
steve40th
CF Senior Member
St. Jude Donor '03 & '05
Where can you get one and what cost? Steve corvettesrule@hawaii.rr.com
steve40th is offline   Reply With Quote
Old 07-28-2002, 01:48 PM   #5
gcrouse
CF Senior Member
gcrouse's Avatar
Default Re: If I rplc stk fuel pump with a Walbro pump will I need the aux inline pump? (steve40th)
Here's a fun page showing flow rates and tech info on Walbro pumps. The GSS307 is good up to 60psi; the GSS340 can do 80-90psi for those using an FMU.
http://www.gnttype.org/techarea/fuel...albroflow.html
Muscle Motors sells these pumps for $119 and $139, respectively; that's where I bought mine...
http://www.musclemotors.com/specials.htm
Old 07-29-2002, 01:54 PM   #6
SPD DMN
CF Senior Member
Cruise-In I Veteran
SPD DMN's Avatar
Default Re: If I rplc stk fuel pump with a Walbro pump will I need the aux inline pump? (gcrouse)
I got mine from Muscle motors too. Get the Mustang kit though. Same pump at less costs.
Old 07-29-2002, 06:15 PM   #7
gcrouse
CF Senior Member
gcrouse's Avatar
Default Re: If I rplc stk fuel pump with a Walbro pump will I need the aux inline pump? (Vette92)
Yeah it's the same pump, but the GM kit include the wiring harness adapter and correct size fuel sock.
Reload this Page If I rplc stk fuel pump with a Walbro pump will I need the aux inline pump?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
