Hi...I own a 96 CE, and I want to Supercharge it. Now I can install itmyself. I have a deal I dont want to miss. ATI Procharger P-1SC w/Intercooler...full setup. Plus Autometer Gauges. All new stuff. Several people say that I cant just bolt on this baby, that i will do some serious piston damage at 8psi. Keep in mind this is a stock motor. Is anyone else running this blower? Any words to the wise? thanks
Is the P1-sc you are buying from another Vette? I am pretty sure the P1-sc from any other Lt1 (Camaro)won't work. Boost can be turned down as well as up, but eventually you will have to rebuild depending on how heavy your right foot is.
the P-1SC intercooled is the ONLY way to go. I have had no problems on my blown 96. Installation is not as simple as they claim. Took me "a mechanic" about 20 hours to make a very neet instalation.
I'm considering the procharger and trying to decide how much
of the install to attempt myself.
Did you have to relocate any of the power steering stuff?
Cut the radiator shroud? Set up fuel controller on a dyno ?
Anything else that doesn't just bolt on ?
