Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-01-2002, 06:06 PM   #1
Tomas
CF Senior Member
Tomas's Avatar
Default 30lbs/hrs injectors. How much HP will they handle?
Hello
Accel 30lbs/hrs injectors. How much HP will they handle?
regards
tomas
Tomas is offline   Reply With Quote
Old 07-02-2002, 06:46 PM   #2
ED89
Junior Member
ED89's Avatar
Default Re: 30lbs/hrs injectors. How much HP will they handle? (Tomas)
Check out this site it will show you how to work it out.
http://www.rceng.com/technical.htm
ED89 is offline   Reply With Quote
Old 07-07-2002, 10:20 AM   #3
Greenbeast
CF Senior Member
Send a message via ICQ to Greenbeast Send a message via AIM to Greenbeast Send a message via MSN to Greenbeast
I think the maximum power for 30 lb injectors are 500hp in a C4...
Greenbeast is offline   Reply With Quote
Old 07-09-2002, 02:54 AM   #4
vader86
CF Senior Member
vader86's Avatar
I wouldnt push them over 500hp, but i think theyre best suited for 400-450hp work
vader86 is offline   Reply With Quote
Old 07-16-2002, 03:36 PM   #5
gcrouse
CF Senior Member
gcrouse's Avatar
Hey Tomas- if that's you with the supercharger, you really ought to think about 36 lb/hr injectors. Even if you don't need them now, you will when you turn up the boost...
gcrouse is offline   Reply With Quote
Old 07-17-2002, 08:00 AM   #6
snake killer
CF Member
snake killer's Avatar
Default Re: 30lbs/hrs injectors. How much HP will they handle? (vader86)
ok, here's a ?. My car calls for 24lb injector now. When I use nitrous it calls for 30lb injectors. If I use 30 lbers now, the car doesn't idle very well. What do I do to solve this problem? Maybe put in 27 lbers? And go for the in between?
The same goes for the fuel regulator setup. Set it one way too low set it the other too high. Does it hurt to set the fuel flow regulator at @ 60 and leave it there? The correct setting without nitrous is @47. I hear setting it high is very hard on the injectors.
[Modified by snake killer, 3:54 AM 7/19/2002]
snake killer is offline   Reply With Quote
Old 09-19-2002, 02:51 AM   #7
black_89_vette
CF Senior Member
black_89_vette's Avatar
Send a message via MSN to black_89_vette
Default Re: 30lbs/hrs injectors. How much HP will they handle? (snake killer)
My car is already making 400 to the fly (335 rwhp) , I am using 30 #'s and it seems fine. But, if I am using a 150 hp nitrous kit, that'd push it well beyond the 500 hp mark. So, should I consider upping the injectors?
black_89_vette is offline   Reply With Quote
Old 09-19-2002, 07:12 PM   #8
SPD DMN
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
SPD DMN's Avatar
Default Re: 30lbs/hrs injectors. How much HP will they handle? (black_89_vette)
You don't include the Nitrous power into the equation if you are running a wet shot. The additional fuel needed for the power is introduced through the nitrous mixture and not the injectors.
I am right at 500 flywheel horsepower all motor and run 30# injectors. At 50psi I am running a little rich (12:1 a/f) and at 85-90% duty cycle at 6-6500k rpms.
SPD DMN is offline   Reply With Quote
Old 09-26-2002, 07:00 AM   #9
Tomas
CF Senior Member
Tomas's Avatar
2 weeks ago a pushed my car to 11.72 run. I have calculate the time and the weight so it has to have over 500HP. So now I definitely has to go for bigger injectors. I think I go for 50lbs/hrs. Then I can aslo add NOS. Whats the best make of injectors? Partnumbers? Any other help that I can use
regards
Tomas
Reload this Page 30lbs/hrs injectors. How much HP will they handle?
Tags
30, 30lb, 47, handle, horsepower, hp, injector, injectors, lbs, support
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
