Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-26-2002, 03:37 PM   #1
yellow-cat
Junior Member
yellow-cat's Avatar
Send a message via AIM to yellow-cat
Default NX 150 lean on take off............
Running a 150 shot of NX, and it is running a little lean on take-off. At higher speeds, no problem. Supposed to use a 62 N20 and 38 fuel jets, I already bumped up fuel jet to 42 with the same results. The next fuel jet is a 52, but that seems like it would then be too lean. Anyone have some suggestions?
yellow-cat is offline   Reply With Quote
Old 06-28-2002, 05:36 AM   #2
SPD DMN
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
SPD DMN's Avatar
Default Re: NX 150 lean on take off............ (yellow-cat)
based on what? Dyno wide band?
Are you purging the nitrous line? Did you use the lines provided in the kit or did you use shorter/longer lines between the selenoids and the nozzle. How is the fuel pressure? Could be spiking the fuel pump and not being able to maintain pressure momentarily.
SPD DMN is offline   Reply With Quote
Reload this Page NX 150 lean on take off............
Tags
lean, nx
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A really Dumb, but easy, NO2 question Lancer033 C5 Forced Induction/Nitrous 18 01-16-2004 02:45 AM
Nitrous Question?? kabnvtt C4 ZR-1 Discussion 35 10-19-2002 12:04 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
