Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-25-2002, 06:42 PM   #1
snake killer
CF Member
snake killer's Avatar
Default Lose of power with N2O
When I activate my N2O system, it actually feels like I'm Losing power. How can that be? I know the nitrous is being injected into the engine. That is, if the tank was really filled with Nitrous Oxide to begin with. ????????????
snake killer is offline   Reply With Quote
Old 06-25-2002, 08:28 PM   #2
James94LT1
CF Senior Member
James94LT1's Avatar
Default Re: Lose of power with N2O (snake killer)
Thats really weird sounding. What kit do you have? Wet/Dry?
James94LT1 is offline   Reply With Quote
Old 06-25-2002, 09:07 PM   #3
BubbleHead
CF Senior Member
BubbleHead's Avatar
If you have a wet kit, double check your nozzles and jets. If you have them reversed, you will be flooding your motor. It's an easy mistake to make, and fix.
keep us updated.
BubbleHead is offline   Reply With Quote
Old 06-27-2002, 03:26 AM   #4
BubbleHead
CF Senior Member
BubbleHead's Avatar
So, what did you find?
Old 06-27-2002, 07:38 AM   #5
snake killer
CF Member
Can't find what is causing my lose of power. I only have a .037 (50hp)jet in stage one and a .042 (75hp) jet in stage 2. ????????????? It actually has less power than if I hadn't used the N2O at all. Something very strange going on.
$3.70 lb. here (Hummelstown, Pa.), by the way.
[Modified by snake killer, 5:42 AM 6/27/2002]
[Modified by snake killer, 4:27 PM 6/27/2002]
[Modified by snake killer, 8:53 AM 7/14/2002]
Old 06-27-2002, 02:32 PM   #6
BubbleHead
CF Senior Member
BubbleHead's Avatar
Can you give us some details about your set-up? Like what kit, wet or dry system, etc....
Old 06-28-2002, 02:21 AM   #7
snake killer
CF Member
Dry system.
[Modified by snake killer, 8:54 AM 7/14/2002]
Old 06-28-2002, 01:08 PM   #8
BubbleHead
CF Senior Member
BubbleHead's Avatar
As long as the nozzle is facing the motor, it shouldn't be a problem. And the advice about moving it away from the motor, allowing the nitrous to mix, is good advice.
Old 06-28-2002, 06:24 PM   #9
KLLRVET
CF Senior Member
KLLRVET's Avatar
What is your bottle pressure? It needs to be 900lbs, if it is lower, you will run a LOT richer and slower than you need to be.
KLLRVET is online now   Reply With Quote
Old 06-30-2002, 12:26 PM   #10
snake killer
CF Member
Default Re: Lose of power with N2O (KLLRVET)
THE BOTTLE PRESSURE (AFTER BEING IN THE SUN) 1200LBS. sTILL HAVE NO IDEA WHY THE N2O ISN'T WORKING. IT SHOULD WORK!
[Modified by snake killer, 10:27 AM 6/30/2002]
Old 06-30-2002, 07:23 PM   #11
black bart
CF Senior Member
black bart's Avatar
Remove the nos line from the nozzle turn on key arm system press on throttle switch see if it blow nos sounds like pluged line or solenoid if this is new system and has never worked you have a blockage did you use tape on threads this is a no-no on the nos side of the system. also check ground on the solenoid. You are getting gas and no nos. Let us know what you find. :seeya
black bart is offline   Reply With Quote
Old 07-01-2002, 01:26 AM   #12
BubbleHead
CF Senior Member
BubbleHead's Avatar
He wrote that he is running a dry system so, I'm not sure how he can be running rich.
:confused: I'm stumped!!
Old 07-01-2002, 07:21 AM   #13
snake killer
CF Member
Default Re: Lose of power with N2O (black bart)
The nitrous comes out with the engine off, the switch on and the wot switch activated, just like it should. Completely baffled. It should work. I can't figure out where i'm getting the power lose or why. Must take it for a dyno check to see how my fuel/air is doing.
[Modified by snake killer, 5:10 PM 7/3/2002]
[Modified by snake killer, 5:14 PM 7/3/2002]
Old 07-02-2002, 07:36 PM   #14
black bart
CF Senior Member
black bart's Avatar
Quote:
The gas comes out with the engine off. Completely baffled. It should work.
If the nitrous came out of the line then the nozzle must be pluged because the only way it could slow down is to be way rich.
When the system activates the injectors are injecting more fuel but without the nitrous it is way rich check everything again it is pluged somewhere. Wish you lived close to me I"m sure I could fix it in just a few minutes. Good luck. :cheers:
Old 07-08-2002, 04:13 PM   #15
BubbleHead
CF Senior Member
BubbleHead's Avatar
I'm completely stumped!!! :crazy: Let us know what you find out or if you have any new info for us.
Old 07-14-2002, 10:47 AM   #16
snake killer
CF Member
update---- had the car dynoed. It showed that up to 100 hp n2o the car worked fine. After 100 hp my computer sensed a lean condition and dumped tons of fuel into the engine causing my lose of power. Now, what to do about this problem? Why is my computer over reacting? The guy at the dyno shop said that I should go wet and inject fuel into the air intake so the computer won't get that lean condition. Isn't fuel in the air intake dangerous? I guess I'll start out with very small jets and work my way up.
My goal is 200 hp.
[Modified by snake killer, 8:51 AM 7/14/2002]
Old 07-14-2002, 02:21 PM   #17
BubbleHead
CF Senior Member
BubbleHead's Avatar
WOW, I have never heard of that before!!! :eek:
All intakes prior to fuel injection had a mixture of fuel and air pass through it so, it's not a big deal to use a wet system. I actually prefer the wet system.
I'll have to think about why your computer is leaning out the car, it's an interesting problem.
Old 07-14-2002, 04:49 PM   #18
Hammer
CF Senior Member
Support Corvetteforum!
Hammer's Avatar
Keep us posted.
Hammer is offline   Reply With Quote
Old 07-14-2002, 09:42 PM   #19
red-y
CF Senior Member
red-y's Avatar
Default Re: Lose of power with N2O (Hammer)
Keep on posting - I am not happy with my dry system, considering going wet because it just does not hit.. :smash: :crazy:
red-y is offline   Reply With Quote
Old 07-15-2002, 02:46 AM   #20
bill mcdonald
CF Senior Member
Where exactly are you injecting the N2O in the motor at? A single nozzle? IN a throttle plate? in the air filter tube?
bill mcdonald is offline   Reply With Quote
Reload this Page Lose of power with N2O
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
turbo NICK YOSKIN C5 Forced Induction/Nitrous 35 03-01-2005 12:02 PM
224/224, 114, .581 too much for daily driver??? Jack Behrle C5 Tech 42 04-20-2004 09:07 PM
Is Nitrous considered 'Forced Induction'? Pipes C5 Forced Induction/Nitrous 48 08-21-2003 02:48 PM
Any thoughts on my next cam? Phil97SVT C5 Tech 10 10-30-2002 10:14 AM
Would you do the LPE Magnuson Supercharger or a Stage II H/C???? Silver TT C5 Tech 40 07-06-2002 04:12 AM
Need more power, I got beat by a BMW!! Jay M C3 Tech/Performance 29 09-10-2001 03:07 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
