Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-22-2002, 05:35 PM   #1
Stolit
CF Senior Member
Stolit's Avatar
Default How boost-friendly is the L98?
Okay. Let's assume for a moment that the L98's heads, pistons, rods, etc. could handle an incredible amount of boost. So much that the block would crack before anything else. Let's assume, for argument's sake, that this is the case (I know it isn't). How much boost would you be able to throw at it from a S/C or turbocharger with the stock compression ratio? I know, this depends on many things. However, assuming the block is the only concern, how much could you throw at it without cracking or getting very close to cracking the block?
Thank you.
-Jeremy
Stolit is offline   Reply With Quote
Old 06-22-2002, 08:57 PM   #2
AKS Racing
CF Senior Member
AKS Racing's Avatar
Default Re: How boost-friendly is the L98? (Open Headers)
Boost is a relative term. One person producing 6 psi may be pushing 1300 cfm, while someone else pushing 12 psi may only be pushing 1100 cfm. The higher boost may be due to the fact that they are running very restrictive heads and intake. I think what you are asking, is how much HP an L-98 block can handle. Boost tells nothing.
In stock form, I would get concerned at the 450-475 HP mark. Step up to splayed billet mains, professional blueprinting, and a thick deck cylinder head, and I would say that 800 HP is doable. Some people push further, but I think that these are safe guidelines.
BTW, the factory pistons ring lands will lift above 6 psi. I ran for several years, but ran rich. It is not a case of if they will lift, but when they will lift. The blower manufacturers do not offer this info unless you ask. Most times you ask after they have already lifted. Oh well!
Hope this helps,
Aaron
[Modified by AKS Racing, 6:01 PM 6/22/2002]
AKS Racing is offline   Reply With Quote
Old 06-22-2002, 10:22 PM   #3
gcrouse
CF Senior Member
gcrouse's Avatar
Given the highest octane gas, running the highest effective compression ratio (static + boost) said gas allows, and zero-gap rings, you would still never generate cylinder pressures high enough to crack the engine block- assuming it burns smoothly without detonation. If it goes into detonation and you have very strong pistons/rods/crank, you will hammer the main bearings and stretch the caps badly, but still probably never crack a bore (unless maybe you went .090" over on the rebuild).
As you mentioned this is an unrealistic question because so many other things will break first: head gasket, rings, pistons, piston pins, bearings, rod bolts, rods, crank, warped head.
Just as a reference point, people on the Z28 forced induction page are running 18-20psi of boost on stock O-ringed blocks with lowered compression 8.2:1.
gcrouse is offline   Reply With Quote
Old 07-07-2002, 07:56 PM   #4
Bruce
CF Senior Member
Bruce's Avatar
Send a message via AIM to Bruce
Default Re: How boost-friendly is the L98? (gcrouse)
with the stock shortblock. I would not worry about the block will crack. Your pistons, rods will go before your block. Running boost on stocker, pistons are your main concerns not your block.
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
Bruce is offline   Reply With Quote
Old 07-10-2002, 06:00 PM   #5
krivera
CF Senior Member
krivera's Avatar
Send a message via AIM to krivera
Default Re: How boost-friendly is the L98? (Bruce)
10psi with Juice :D
95K
krivera is offline   Reply With Quote
Reload this Page How boost-friendly is the L98?
Tags
block, corvette, crack, headers, hp, l98, open
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Should I swap l98 to lt1 for SC? scm6079 C4 Forced Induction/Nitrous 27 05-17-2005 03:18 PM
Horsepower vs. Torque 03LingenfelterC5 C5 Tech 11 03-03-2005 09:31 PM
[FI Newb] Proper turbo sizing? (Long) Dale1990 C4 Forced Induction/Nitrous 9 03-01-2005 03:50 AM
I used to know... but I'll ask again, HP vs TQ ruby76 C3 Tech/Performance 31 01-30-2005 12:35 PM
LS2/LS7 Engines not very efficient? djhartm C6 Corvette General Discussion 37 01-29-2005 01:37 PM
RWHP vs RWT Fastbasser Performance Results 33 12-23-2004 04:49 PM
D1 Procharged L98 Design Excersise... doug_dayson C4 Forced Induction/Nitrous 10 09-23-2003 03:00 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
