Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-17-2002, 05:33 PM   #1
Tomas
CF Senior Member
Tomas's Avatar
Default Please help, Timing set for Supercharged L98
Hello everyone.
I have so high exhaust temp, so I think I have set the timing wrong.
What timing do you guys have with the ESC cable connected/disconnected
I hope someone will answer me soon
thanks
regards
Tomas
Tomas is offline   Reply With Quote
Old 06-17-2002, 07:41 PM   #2
lead foot 85 vet
CF Senior Member
Default Re: Please help, Timing set for Supercharged L98 (Tomas)
my 85 is set at 6 degrees without cable and I think it's at 10 or 12 with the cable .............I only checked it once with the computer hooked up and it was by mistake.....also I run an intercooler with 8 psi boost so I run stock timing. hope this helps.
lead foot 85 vet is offline   Reply With Quote
Old 06-17-2002, 08:07 PM   #3
black bart
CF Senior Member
black bart's Avatar
Set at 6 degrees btdc with cable unhooked then hookup cable and rev the engine use timing light to see if ecm is advancing the timing. :seeya
black bart is offline   Reply With Quote
Old 06-18-2002, 04:01 PM   #4
krivera
CF Senior Member
krivera's Avatar
Send a message via AIM to krivera
Default Re: Please help, Timing set for Supercharged L98 (black bart)
dont know let me go home tonight and check that? but i am running 10psi with intercoolers.
krivera is offline   Reply With Quote
Reload this Page Please help, Timing set for Supercharged L98
Tags
l98, setting, supercharged, timing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
